Rear driveshaft snapped - Page 2 - JeepForum.com
post #16 of 45 Old 12-11-2012, 05:43 PM
2006_Sport
Originally Posted by wildwapiti View Post
I bought the vehicle lifted, so I guess there's no way of telling if the vibes were due to the lift or not (although what else would they be from?), but no they were not excessive. And there was not an increase in them recently.
How bout this, when you accelerate, did you ever feel any vibrations in the *** of your seat? if so, those are usually driveline related.
Though, I don't see how vibes would snap a main shaft like that. Are those old u joints seized up?
2006_Sport is offline
post #17 of 45 Old 12-11-2012, 05:51 PM Thread Starter
wildwapiti
Sheesh, how many ways can I answer this? Haha... There were some driveline vibes, but I wouldn't call them excessive. Not nearly as bad as my lifted WJ. And there were more vibes in the floorboard than the seat.
The ujoints seem to swivel pretty freely. The rear most set on the diff. end are a little sticky, and obviously damaged from being ripped out of their straps, so tough to tell if that is causal or due to the driveshaft shedding.
wildwapiti is offline
post #18 of 45 Old 12-11-2012, 05:54 PM
2006_Sport
hahah my bad man. You said you weren't sure so I was just trying to make sure so you can rule that out. Minor vibes shouldn't do that. That's ****ing weird.
post #19 of 45 Old 12-11-2012, 05:58 PM Thread Starter
wildwapiti
Yessir. I was thinking maybe the straps on the diff. end loosened up and that end of the DS fell out and subsequently torqued the shaft out, but I think the chicken came before the egg. There wasn't a whole lot of banging or clanging as you'd think there'd be in the former scenario.
post #20 of 45 Old 12-11-2012, 06:11 PM Thread Starter
wildwapiti
So my options are replace t-case or install SYE and get a new driveshaft? It looks like I could replace the mainshaft itself, but they are as much as a used t-case!
post #21 of 45 Old 12-11-2012, 06:13 PM
rchase559
Or get a used main shaft...
rchase559 is offline
post #22 of 45 Old 12-11-2012, 06:14 PM Thread Starter
wildwapiti
yea true... been looking!
post #23 of 45 Old 12-11-2012, 06:26 PM Thread Starter
wildwapiti
and any idea what the giant metal disk is in the picture? I guess a "balancer"? Does the main shaft come out of it or is it pressed in? I assume pressed, because it's not budging... Where would I find a new one of those? I also don't have a housing extension which is pictured in most NP231 pictures... What's the deal?
post #24 of 45 Old 12-11-2012, 06:31 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Driveline vibes excessive or otherwise are bad. If they exist, they remove your ability to diagnose when your u-joints are dying, about to die or are dead. They also remove your ability to tell when something is wrong other than a dying u-joint like a driveshaft out of balance, improper pinion angle, loose trans mount, or a myriad of other issues that can lead to catastrophic failures like this one.
If all that happened is what you show which is a busted mainshaft in the t-case, consider yourself very lucky. Typically the shaft swinging around takes out the exhaust, fuel and brake lines, fuel pump wiring, and puts a few holes in the tub for good measure.
I will tell you right now that the chances of you being able to re-use that driveshaft are about 1 in 500. They don't respond very well to being slammed against anything and will either bend or be out of balance.
You need to take a much closer look at stuff and see if anything else is damaged.
At the minimum, you are going to need a new driveshaft and new tailshaft for the t-case and I'll be very surprised if the tailcone and bearing are still good although chances are good they could be.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #25 of 45 Old 12-11-2012, 06:34 PM
jrallen
I've had it happen to me before!
A friend and I were test driving an '04 when he shifted into third and the ds flew out. We picked up all of the broken parts, drove a little way in front wheel drive, then parked it and waited for the dealership to come tow it. Their explanation was that they had replaced the rear pinion bearing, and used the wrong sized bolts the reattach the ujoint straps, hence, the rear came loose, spun a few times, beat four holes in the muffler, then snapped off of the output shaft on the tcase. Quite an interesting test drive if you ask me... and no, neither of us bought that jeep.
jrallen is offline
post #26 of 45 Old 12-11-2012, 06:38 PM
2006_Sport
All of this, and not because it's Blaine, because I was stupid enough to run with vibes for so long. Pretty soon I'll have to replace my rear pinion bearing (which isn't hard to do, just could have been easily prevented) and probably the rear output bearing on the Tcase. It still baffles me that I have vibes like that on such a low lift. Regardless, I'll be buying an SYE and those new bearings this Christmas. I've been fortunate enough to catch u joints before they die, I'm just tired of worrying about it. Should have listened 3 years ago, but I was like every other teenager that thought they had the world figured out
post #27 of 45 Old 12-11-2012, 06:43 PM Thread Starter
wildwapiti
Good info! It's actually my girlfriends TJ (and this is her account), but she insists no driveline vibes, and I cannot recall any while driving it myself (the few times I did). The driveshaft did smack the muffler one good time, but that is all the damage that I can tell. Seem like it spun once and then fell right out. So the best and or/ cheapest route would be new mainshaft, and then either a new driveshaft, or an SYE with a new driveshaft? Or possible a new (used) Tcase and a new driveshaft. Is there a way to see if the driveshaft is still balanced? It is pretty beefy and looks straight to my dumb eyes.
post #28 of 45 Old 12-11-2012, 06:46 PM Thread Starter
wildwapiti
HAHA! WOW! We replaced the rear pinion bearing earlier in the summer. Thought we torqued the strap bolts down nice and snug, but they look loose. The straps are not ripped. Maybe a whoops...
post #29 of 45 Old 12-11-2012, 07:12 PM Thread Starter
wildwapiti
post #30 of 45 Old 12-11-2012, 07:13 PM
srlbotanical
My guess is that it let go at the rear axle first. made one good flip and broke off at the t-case.
Other then that I have nothing to add that hasnt already been posted...
I also have a stock tail shaft and stock tail housing that I can send you if needed. Send me a PM if you need them...Good Luck and let us know what you find when you dig in a little further.
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
