Rear driveshaft removal - JeepForum.com
post #1 of 4 Old 12-07-2011, 06:29 AM Thread Starter
Easykill22
So I broke my rear driveshaft going to work and I am trying to remove it. I used the search and all the suggestions said to unstrap it at the axle end and then it just slides out. But all of the threads said your transfer case will lose fluid then so how do you remove the rear shaft and still be able to drive it on the front shaft?
It may seem like a dumb question but I am stumped.
Red Jeep Club #591
Firefighters Jeep Club
1998 Jeep Wrangler TJ
Easykill22 is offline
post #2 of 4 Old 12-07-2011, 06:32 AM
jeepinhokie
the newer TJ transfer cases are capable of having the driveshaft pulled out without a loss of fluid.
edit: here's a link for more info.. http://www.jeepforum.com/forum/f9/re...emoval-210795/
HOKIES UNITED!
jeepinhokie is offline
post #3 of 4 Old 12-07-2011, 06:35 AM Thread Starter
Easykill22
Ok thank you for the help
Red Jeep Club #591
post #4 of 4 Old 12-07-2011, 07:38 AM
mdm
Farm Wheeler
The older TJ transfer cases are the same.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
rear driveshaft removal? rdtj TJ Wrangler Technical Forum 3 02-24-2011 07:27 PM
rear driveshaft removal chickenhawk7 JK Wrangler Technical Forum 3 06-30-2010 08:23 PM
rear driveshaft removal splint2003 JK Wrangler Technical Forum 1 06-26-2010 05:01 PM
Rear driveshaft removal - boot squib TJ Wrangler Technical Forum 1 02-14-2009 09:01 PM
Rear Driveshaft Removal RedSyphon TJ Wrangler Technical Forum 9 05-21-2006 03:00 PM
