Quantcast Rear driveline vibes at 50 mph - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear driveline vibes at 50 mph
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 11-15-2008, 07:51 PM   #1
BaddAndy
I have an 01 TJ w/TW DS and SYE. I swapped in Rubi D44s and had to get rear CV driveshaft shortened 1.5 inches and rebalanced. The angle installed is 15 degrees and the pinion 1 degree below that. I now have vibes that get real annoying above 50mph and get worse as speed is increased. I removed front DS and it's still there. Removed rear DS and she is smooth as can be up to over 65mph in front wheel drive. So I lower TransferCase 1 inch and and readj. pinion, but no difference. DS angle is now 12.5 degrees. Do I need to keep dropping it or do you think the DS needs balancing? Has anyone fixed a vibe by reindexing the shaft one or more splines?
2001 Jeep TJ Sport, 4.0L, NV3550, F-R Rubi axles & lockers, 3.25" RC lift w/RS9000s, JKS 1.25 BL/MML, RE Adj. Flex CAs, SYE/TW driveshaft, Half/Full doors, A-Z sliders, Smittybuilt bumpers/tirecarrier, 33/12.5/15 BFG MTs on 15X8 Gamblers/1.25 spacers
http://i10.photobucket.com/albums/a1...P/FWsheild.jpg
BaddAndy is offline   Reply With Quote
Glock Forum
