rear drive shaft removal - JeepForum.com
post #1 of 21 Old 11-15-2005, 08:17 PM Thread Starter
FifteenCents
I was told that I can remove my rear drive shaft on my TJ and not lose all my transfercase fluid. I think this is true on 97 and up. Was there a change in the Transfer case on the TJs with the slip yoke that allows for this?
The above post is my opinion and I have no facts to prove it... :)~
The ultimate TJ owners only forum
FifteenCents is offline
post #2 of 21 Old 11-15-2005, 08:20 PM
Railtech
That is a YJ you are thinking of. Just take the straps off the yoke and a big screwdriver under the u-joint to unseat it and pull off the t/c.
Railtech is offline
post #3 of 21 Old 11-16-2005, 06:11 AM
paroxysym
2007 WK
to remove simply undo the straps on the yoke, remove the two u-bolt straps on the lower part of the shafts towards the rear, pull the driveshaft away from the t-case and its off... thats how i did it to replace the u-joints.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #4 of 21 Old 11-16-2005, 08:38 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
To clarify, the TJ's driveshaft can be removed without the t-case leaking. It's the '95 and older YJ that leaks the ATF out of the t-case if the driveshaft is removed.
Jerry Bransford is offline
post #5 of 21 Old 11-16-2005, 01:25 PM Thread Starter
FifteenCents
Thanks Jerry
That was the answer I was looking for...
post #6 of 21 Old 11-16-2005, 01:37 PM
RubiconSS
RubiconSS's Avatar
I've had mine on and off a dozen or so times.
Have a roll of duct tape handy.
When you disco the back of the DS (where it goes into the joint on the rear diff)
Tape those caps on so they don't pop off and splay your needle bearings all over the floor.
'05 Rubicon (to go) '01 CamaroSS(to go fast)
RubiconSS is offline
post #7 of 21 Old 11-16-2005, 06:53 PM
Raxmar
Kindly then, answer me this: If you remove the rear driveshaft from a 97-newer Wrangler, is it safe to drive the vehicle without the driveshaft? I have had the front driveshaft out of my 97 for about 5 days now, waiting for a rebuild. No problems. Just wondering if it could be done the other way around - no rear shaft, operating on just the front shaft.
Raxmar is offline
post #8 of 21 Old 11-16-2005, 06:57 PM
U.S.MarineLJ
U.S.MarineLJ's Avatar
DC4WD told me it would be alright. I'm skeptical however. The reason I asked is because I'm now without my Jeep until my rear DS is made as I just installed my SYE. That is a good question and I'm glad you asked, I'm curious as well.
John.
Great site to read about and review Jeep related products.
Awesome site with writeups.
Another awesome site for writeups.
U.S.MarineLJ is offline
post #9 of 21 Old 11-16-2005, 07:21 PM
Jerry Bransford
Administrator
Yes, a TJ can be safely driven without the rear driveshaft... definitely. Safely as in nothing will happen to the transfer case, rear differential, front axle, etc.. Now if there is a locker in the front axle, then it would be engaged during the time the TJ is in 4wd which would make the steering difficult on the street.
post #10 of 21 Old 11-16-2005, 07:24 PM
U.S.MarineLJ
So even at freeway speeds it will be alright? I'm talking like on the 15.
post #11 of 21 Old 11-16-2005, 07:33 PM
Jerry Bransford
Administrator
Unlocked, it's just like a fwd car.
post #12 of 21 Old 11-16-2005, 09:46 PM Thread Starter
FifteenCents
be careful
If you drive without the front drive shaft you must put the transfercase in 4Hi, so the chain will spin the pump. The fluid pump is on the front driveshaft side of the transfercase. Without the driveshaft to spin the transfercase it will overheat. And chain failure will happen.
post #13 of 21 Old 11-16-2005, 09:51 PM
U.S.MarineLJ
Cool, thanks Jerry.
post #14 of 21 Old 11-16-2005, 09:57 PM
Jerry Bransford
Administrator
Not really. The TJ's NV231 transfer case has a true neutral for the front driveshaft mechanism when in 2wd and it doesn't need the front driveshaft spinning to lubricate that part of the mechanism. If that weren't the case, the thousands of us running unlocked manual hubs on the front axle that stops the front driveshaft from spinning in 2wd would have beaucoup t-case problems.
post #15 of 21 Old 11-17-2005, 09:06 AM Thread Starter
FifteenCents
Hummm!
Jerry,
Make sense when you put it that way, but that is different that what I was told.
Maybe it was the rear drive shaft that spins the pump?
Hummm!
Help!! Front drive shaft U-Joint removal! jeeptrash TJ Wrangler Technical Forum 6 09-09-2009 07:07 PM
Front drive shaft removal fire239 TJ Wrangler Technical Forum 12 12-02-2008 07:13 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
Front Drive Shaft Removal GSSFC TJ Wrangler Technical Forum 6 05-29-2008 07:25 PM
rear drive shaft removal help 2008redrockjk TJ Wrangler Technical Forum 5 04-14-2006 04:20 PM
