#1 | |
Rear Door dome light switch?
Has anyone found a kit or have a suggestion for a dome light switch on the rear door?
#2 |
I just put a couple of Sylvania Dot-It lights back there, but they don't really help too much...but they are "mejore que nada" (better than nothing)!
![]() BTW, I'm originally from Jax, so I thought I'd just post up to say 'hi!' Cheers! M2 |
#3 |
i am going to do what i did to my pick up; i bought fog lights and installed them in the bed then hooked up a simple switch in the cab. for my jeep i am going to try and find a cord light or something mount it out of site and put in a switch or 2 may colored lights too. bit of work but i think it will be cool
#4 |
I've been thinking of using the bracket for the contacts for the third brake light (which I tossed) to mount a pin switch to a real dome light.
Those stick up lights work great if you get a brighter one. I use them in my boats, they're perfect. Some of those LED units aren't any brighter than a candle, get bright ones. |
#5 |
Dot-It's are awesome. I just installed one of the long thin ones on my roll cage with some zip-ties. Lights the interior up better than the OE dome light did.
Thinking of adding two more thin ones behind the sun visors, purely for lighting up maps. Add a couple others to the luggage area. |
#6 |
The light on the roll bar is of some help to un-load groceries and such, yep more light would be good too, I just hate having to go around to open a door to turn on the lights
#7 | |
Jeep
Come on... you aren't fully converted to GPS yet???? ![]() ![]()
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#8 | |
I was referring to Mischievously Acquired Pornos ![]() This is my navigator: ![]() Jokes... In all seriousness I enjoy participating in the local fun-drive events where you get rally style course notes. The next event is an over-nighter. ![]() |
#9 |
i wear foil underwear too
I wouldn't think a switch for a light would be that hard. I would probably use a leftover cheapo wally-world rock-light. that should be enough to see by.
I use CatEyes on the visors. http://www.lakemichiganangler.com/store/Cats_Eyes_Cap_Lights.htm <-for illustration purposes only. They're like 3 bucks anywhere else.
ಠ_ಠ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
