Quantcast Rear Differential Need To Be Replaced?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear Differential Need To Be Replaced??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 12-18-2007, 12:51 PM   #1
DawgAaron
Went to put some new tires on my '01 wrangler sport yesterday and everything went well except that I discovered that my rear end was leaking.
Talked to a mechanic friend of mine and, after he took a look at it, he said that it could be a pretty big deal.
Apparently this is a rather common thing in Jeeps, but mine is leaking at a higher rate than normal. There is evidence of blowback on the bottom of my gas tank from the thing leaking while i'm driving. I need some help on what to do.
I have a picture of the leak below. Hopefully that link will work.
http://mail.google.com/mail/?ui=1&attid=0.1&disp=inline&view=att&th=116ee8cea7 350fed
DawgAaron is offline   Reply With Quote
Old 12-18-2007, 12:55 PM   #2
Rocky529
Jeep
Rocky529's Avatar
Link isn't working.. I'm trying to picture what is leaking. Is it just from where the cover mates with the differential?
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 12-18-2007, 01:02 PM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Your link isn't working for me either.
Are you still driving your Jeep? If so, its important that you check your fluid level ASAP.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 12-18-2007, 01:07 PM   #4
DawgAaron
I don't know why it's not working. Anyway, it looks like its leaking from the left side of the differential; where the axle goes into the differential case. Leaking pretty considerably too.
Do you know what would cause this?
I can email a picture if that would help.
Thanks.
Old 12-18-2007, 01:08 PM   #5
DawgAaron
Yes, i'm still driving it. My mechanic told me that it would be good until i come in for an oil change in about a month.
Old 12-18-2007, 01:10 PM   #6
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
First thing I would do is look for a new mechanic
TheBoogieman is offline   Reply With Quote
Old 12-18-2007, 01:28 PM   #7
tman204
No doubt.... "Hey, that leak is normally abnormal!"
tman204 is offline   Reply With Quote
Old 12-18-2007, 01:28 PM   #8
DawgAaron
anybody have any thing a little more helpful?
Old 12-18-2007, 01:32 PM   #9
tman204
A picture of the leak would help a lot, but from what you describe, it sounds like the diff housing is cracked....
Old 12-18-2007, 01:34 PM   #10
EvilM0nkey
the picture is linked to your mail inbox. you need to host the picture somewhere for us to see it.
try www.flickr.com
-Ross
1998 Subaru Forester DD
2002 TJ Sport 4.0 HO (Has some goodies) Weekend play toy
1987 Coleman Columbia
3/4 ton+ tow rig wanted!
EvilM0nkey is offline   Reply With Quote
Old 12-18-2007, 01:39 PM   #11
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Axle leaks are not all that uncommon and rarely are any of them serious. I doubt the housing is cracked which is very rare, it likely just needs a new seal at either the pinion shaft or hub bearing area. Keep it topped off until you can determine the source of the leak. A better link to a photo would be helpful.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 12-18-2007, 01:44 PM   #12
FLATFENDER54
serious though - you need to change mechanics. If thats all he said was it looks serious/its a big deal ...............come back in a month. (that doesnt sound like a good mechanic to me)
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEzhttp://i73.photobucket.com/albums/i225/FLATFENDER54/Off%20raod%20trip%20to%20Colorado%20with%20son%20a nd%20dad/DSC01873.jpg
66 Chevelle(Not a good pic in shed 4 many years)http://i73.photobucket.com/albums/i225/FLATFENDER54/memeorystick512262.jpg
93 ford lighting-trick flow heads 6 psi supercharger http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01636.jpg
1954 WILLYS CJ3B (under construction) http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01301.jpg
99 escort zx-2 my favorite lil gas "sipper" (who cares)lol
USMC "Semper Fidelis"
FLATFENDER54 is offline   Reply With Quote
Old 12-18-2007, 01:48 PM   #13
DawgAaron
Picture Link
http://www.flickr.com/photos/15788779@N06/2121232372/
Old 12-18-2007, 01:55 PM   #14
Jerry Bransford
What about the front where the pinion seal is? If that isn't leaking, could the diff cover seal possibly be leaking? If neither, yeah it could be more than just a seal. I'd jack up the jeep by the frame so the axle can droop down as far as possible (taking the wheels off will reduce how high up you have to jack the frame up). That will let you look the axle over a little more easily so you can spot the source of the leak. Hopefully it's not leaking from where the axle tube is inserted into the pumpkin.
Getting Savvy...
Old 12-18-2007, 01:59 PM   #15
DawgAaron
well i think it is leaking "from where the axle tube is inserted into the pumpkin". What does that mean??
Glock Forum
