Rear Diff Oil level? - JeepForum.com
post #1 of 8 Old 06-30-2010, 02:02 PM Thread Starter
ssb
2015 JK Wrangler
I remember reading somewhere - but cant find the thread or link. My rear Diff is at an angle (not level) - i suppose because of the PO trying to get the pinion angle right with the RE 3.5 lift. Anyways, since it is a bit tilted, wouldn't that mean there could have been less gear oil put in since the fill hole (in my case a rubber plug) is lower? I can swear i read where someone jacked up the rear end to make it higher so they could get more oil in..? What say you?
ssb is offline
post #2 of 8 Old 06-30-2010, 02:05 PM
jeepinmichguy_
do it, it will work fine.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #3 of 8 Old 06-30-2010, 02:07 PM Thread Starter
ssb
2015 JK Wrangler
do you mean lift up the rear and fill it that way or just fill it with the pumkin tilted. Thanks again
ssb is offline
post #4 of 8 Old 06-30-2010, 02:07 PM
95wrangler4life
i know my 8.8 is at a angle, but the fill plug is on the opposite side of the diff, near where the pinion is, but i just filled until i felt it had enough, it took over a gallon! but for the 35 and being on the other side, if you wanted to do something i would jack the right rear tire up and angle the vehicle that way then add more.
You can search the specs in google as to how much fluid it should hold from the factory
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #5 of 8 Old 06-30-2010, 02:09 PM Thread Starter
ssb
2015 JK Wrangler
man you guys a great.. thanks for the most ricky tik responses
ssb is offline
post #6 of 8 Old 06-30-2010, 02:11 PM
jeepinmichguy_
you welcome!
ΜΟΛΩΝ ΛΑΒΕ
post #7 of 8 Old 06-30-2010, 08:56 PM Thread Starter
ssb
2015 JK Wrangler
ssb is offline
post #8 of 8 Old 06-30-2010, 09:23 PM
RubiOR
Clever... And if you install the elbow with the cover off you can trim / grind just right so that it doesn't hit the stock Rubi locker's air tube. If you have that kind of problem.
'06 Solar Yellow Rubicon Unlimited --
Their huge yellow spaceships hung in the air in exactly the same way that bricks don't. -- Douglas Adams, Hitch Hiker's Guide to the Galaxy
RubiOR is offline
rear differential , maintenance , fluid capacity
Diff Fluid Level Poll 2jhanna TJ Wrangler Technical Forum 8 03-14-2009 02:41 PM
diff fluid level question. yellowismellow TJ Wrangler Technical Forum 3 12-29-2008 12:04 PM
Correct diff oil level with adj.control arms set for straighter driveline geometry Trikstr TJ Wrangler Technical Forum 0 03-29-2008 10:14 PM
Diff Fluid Level...IMPORTANT JQlaxTJ TJ Wrangler Technical Forum 6 08-15-2005 07:31 PM
Diff fluid level question 94Wrangler4.0 YJ Wrangler Technical Forum 1 03-11-2005 05:33 PM
