Rear diff lube amt? - JeepForum.com
post #1 of 4 Old 07-30-2010, 10:39 AM Thread Starter
akpauly
Rear diff lube amt?
Hi all,
Was checking fluid levels and rear diff was low (no obvious leaks) so added 80/90 GL until just about to level of hole (as I've always done on previous vehicles) then saw a tag on axle housing listing 80/90 and 6 oz. Is this a correct amt? Just doesn't seem like much!
thanx, Pauly
akpauly is offline
post #2 of 4 Old 07-30-2010, 11:00 AM
Piratejonh
Piratejonh's Avatar
fill it to the bottom of the hole.
Jeep took another piece of my finger today...
Piratejonh is offline
post #3 of 4 Old 07-30-2010, 08:10 PM
Ajamant
X2. Fill to bottom of hole.
04 TJ/3" OME/1" MML/1"BBL/3/4" coil spacers up front/discos/Extended bump stops/adj. Rear track bar/hi-lift/ 33x10.5x15 toyo MT on steelies/Epi9000superwinch/nates front bumper/160amp alternator
06KJ CRD with GDE eco tune/samco's/fumoto/tow package/brake controller
Ajamant is offline
post #4 of 4 Old 07-30-2010, 08:15 PM
SolidBrass
3x for the love of God fill it to the bottom of the hole!
REAR AXLE
194–RBI . . . . . . . . . . . . . . . . . . . . 1.66 L (3.5 pts.*)
216–RBI . . . . . . . . . . . . . . . . . . . . 1.89 L (4.0 pts.*)
* When equipped with TRAC-LOK, include 4
ounces of Friction Modifier Additive.
SolidBrass is offline
axle , oil , capacity , amount , tj , wrangler
how far can you go if no diff lube? need help SpaComponents TJ Wrangler Technical Forum 23 04-21-2008 04:25 PM
Rubicon rear diff lube jdragger TJ Wrangler Technical Forum 21 05-15-2007 10:43 PM
Diff Lube Towny72 YJ Wrangler Technical Forum 6 05-06-2007 07:32 PM
ARB diff lube JQlaxTJ TJ Wrangler Technical Forum 4 12-05-2005 10:26 AM
diff lube, 80W-90 or 75W-140 cantthinkofname TJ Wrangler Technical Forum 2 05-29-2005 09:46 AM
