Quantcast Rear Dana 44 outer axle seals - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear Dana 44 outer axle seals
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 11-24-2008, 02:18 PM   #1
JasonJW
Hi List!
My TJ recently failed inspection because the outer axle seal on my rear Dana 44 is leaking on the drivers side and my brake pads are oily. I'm trying to find the replacement part and I'm finding it harder than I realized.. its a case of too much info, a lot of which conflicts. I always though a Dana 44 was pretty much a Dana 44, but the part numbers seem to vary all over the place and no two pictures look alike. I *think* the part matches the outer seals from the CJ D44s as well.. can anyone verify that and put my mind at ease? For instance, here on eBay:
http://cgi.ebay.com/ebaymotors/Jeep-Parts-OIL-SEAL,-REAR-OUTER-AXLE-dana-44-CJ-TJ_W0QQitemZ120329611821QQcmdZViewItemQQimsxZ20081 106?IMSfp=TL0811061110003r25872
Should I be replacing the inner seals as well? Bearings? I plan on doing both sides (if one is leaking, I figure the other probably is as well, or will be)
Thanks!
02 TJ Sahara, 2.25"BB + 1.25" BL, 32" Maxxis Bighorns
JasonJW is offline   Reply With Quote
Old 11-24-2008, 02:24 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
That seal looks like the right one. Yep, plan on replacing the bearings and bearing retainer at the same time since you can't replace the seal without destroying them to get them off. The bearing and bearing retainer both have to be removed to get the seal off.
Here's how to do the job... http://www.stu-offroad.com/axle/d44/d44-1.htm
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
