Quantcast Rear Corner diamond plate armor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear Corner diamond plate armor
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 01-28-2008, 12:41 PM   #1
SpoiledRotten
Roughin' it smoothly
SpoiledRotten's Avatar
http://www.quadratec.com/products/12525_02.htm
Do you have these body armor pieces?
If so, did they go on with a good tight fit or did you have to work with them? I ask that because the CYA remarks on the site state that they are made with some inconsistencies in them.
Did you have to do anything like seal them to keep junk from getting behind them like weather stripping or something similar?
Did they just pop rivet into place?
Is there anything I should know about them?
Would you order them again if you had it to do over?
Sorry for all of the questions, but I value your experiences. Please share them.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline   Reply With Quote
Old 01-28-2008, 01:00 PM   #2
Crashnburn80
If your looking for black dimond plate corner guards, Mopar also makes them in flat Rubicon Black. These are bolt on, fit tight and include a seal. The powered coat is amazingly durable, it was seeminly impossible to chip off with a point and a hammer when installing my Bestop OS carrier. I am not framiliar with the ones you listed though.
Heres a pic of the Mopar ones:
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Glock Forum
