Rear coil spring replacement for dummies - Page 3 - JeepForum.com
post #31 of 38 Old 07-31-2010, 04:38 PM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
Originally Posted by SolidBrass View Post
Here is one more shot of it for good measure
What does the t-case end of the d/s look like? Is there a double cardon, or is it a slip yoke?
We save dogs:
JBWood05TJ is offline
post #32 of 38 Old 07-31-2010, 04:55 PM Thread Starter
SolidBrass
Well I had to look up what a double cardon is (that tells you how much I know). It does have s SYE and I guess that looks like a double cardon attached to it.
SolidBrass is offline
post #33 of 38 Old 07-31-2010, 05:00 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Your pinion angle is too low...
Knuckelhead is offline
post #34 of 38 Old 07-31-2010, 05:09 PM Thread Starter
SolidBrass
So I need to lengthen upper control arms right? How big of an 'issue' do I have?
post #35 of 38 Old 07-31-2010, 05:16 PM
Knuckelhead
AFSOC Retired
Looks like it. Issue? Not much after you correct it...
post #36 of 38 Old 07-31-2010, 05:43 PM Thread Starter
SolidBrass
Maybe I should rephrase the question? I want to make it proper (trust me I will as I'm a big fan of things being done right) I just would like to know what happens if I don't. The joint lower D/S joint gradually fails? Joints were out faster? Or am I in real danger of some catastrophic 'issue'?
I have lots of thing that i need/want to do so I'm trying to gauge where this falls on the list.
BTW thanks for helping me out.
post #37 of 38 Old 07-31-2010, 05:56 PM
Knuckelhead
AFSOC Retired
Yes. Move this to the top of your list of things to fix...
post #38 of 38 Old 08-12-2010, 09:16 PM Thread Starter
SolidBrass
To wrap up this post. I did set pinion to correct. Replaced U-joint while I was at it. I would recommend buying new straps at same time in case they are warn like mine are. I used the floor jack to get it to right angle and reset upper bar length. *** BAD NEWS COMING ***
Pinion angle reset exposed more problems that i've got several post on. Like elongated holes on upper control arm mounts, and blown out lower control bushings. Good news is now I finally know where all me problems are coming
from on the rear end.
JF is my daddy!
rear , coil , coils , coil spring , removal , replacement
Rear Coil Spring Advice maxruby TJ Wrangler Technical Forum 2 03-08-2010 10:32 AM
Help with rear coil spring pads TJ kooljp TJ Wrangler Technical Forum 7 10-18-2009 09:51 PM
OE front coil spring replacement rgrovogel TJ Wrangler Technical Forum 2 07-25-2008 12:37 PM
Anyone use Rear Coil Spring Retainers conor.davis TJ Wrangler Technical Forum 3 02-26-2007 09:01 PM
Front and Rear Coil Spring Tag #'s?? mkuzmukerau TJ Wrangler Technical Forum 3 11-15-2004 02:55 PM
