Rear coil spring replacement for dummies - JeepForum.com
post #1 of 38 Old 07-28-2010, 10:13 PM Thread Starter
SolidBrass
Do I need to remove bump stops to replace rear springs? With lift do I worry about break lines? How do you pry the top bumper on the bump stops?
JF (and O'Doyle) rules. TY for any reply...
SolidBrass is offline
post #2 of 38 Old 07-28-2010, 10:28 PM
AFjeepMan
it makes life a lot easier and probably necessary to remove the bump stop, and longer brake lines are a good idea if you are looking at anything over a budget boost. what do you mean the top bumper on the bump stops?
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
Relearn your priorities.
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline
post #3 of 38 Old 07-28-2010, 10:36 PM Thread Starter
SolidBrass
I have a 4" lift with busted spring. Replacing spring with RC's that are about 1" taller than mine (i'm told)
Doing some searching online I've seen "remove bump stop" followed by "there is a rubber piece on top you must pry off to get to the bolt". Mine looks like str8 up metal but I've never dug into it proper. Thats why I ask.
Remove rubber bump stop to access bolt/nut... so how to you 'pull' the rubber piece off if that is what is there.
post #4 of 38 Old 07-28-2010, 10:40 PM
AFjeepMan
well if yours is so old and the rubber broke off you may have to use a flat head screwdriver to get at the bolt, or if whoever put the 4" lift didn't put the stock bump stop back in you'll be able to get right at the bolt. Take a look and find out. Fingers can tell as much as eyes can and you don't have to remove the wheel to find out.
edit: or you can fly me out there and I'll fix it in a day
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
post #5 of 38 Old 07-28-2010, 10:57 PM Thread Starter
SolidBrass
I did say "for dummies".
I just like to dot some I's/cross T's before I dig in for first time (me being new). I pre-do every job if I can to be sure I know what I'm doing. (assemble parts and un-assemble if possible) I'm lucky i've not been stuck to bad on something so far that would make a tow required.
This shouldn't be that hard, but the rubber bump stop talk threw me.
*EDIT* yes installer did take some short cut's that i've found. Like 1 of 3 mounting bolts for track bar relocation bracket.
post #6 of 38 Old 07-28-2010, 11:00 PM
AFjeepMan
WOW!!! impressive
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
post #7 of 38 Old 07-29-2010, 06:22 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Why?...
Knuckelhead is offline
post #8 of 38 Old 07-29-2010, 06:54 AM
j_niko
2009 JK Wrangler
Originally Posted by Knuckelhead View Post
Why?...
Because the distance from the frame to the caliper/drum is increased. takes all the slack out and they can rupture.
j_niko is offline
post #9 of 38 Old 07-29-2010, 07:11 AM
Knuckelhead
AFSOC Retired
The OP is talking about the rear springs...
post #10 of 38 Old 07-29-2010, 07:21 AM
j_niko
2009 JK Wrangler
anything over a budget boost........
j_niko is offline
post #11 of 38 Old 07-29-2010, 07:23 AM
Knuckelhead
AFSOC Retired
No new brake line is needed for the rear axle with a suspension lift...
post #12 of 38 Old 07-29-2010, 06:56 PM Thread Starter
SolidBrass
Here is a photo of what i'm asking about.
Do I pull off rusty looking bump stop? There is a nut under it?
post #13 of 38 Old 07-29-2010, 07:04 PM Thread Starter
SolidBrass
Also replacements came. Guy from RC that I bought them from said there is an "upside" and "down side"
I called again to be clear and was told there is no up or down side. Looking at them the I think there is no up/down side. What do you think?
post #14 of 38 Old 07-29-2010, 09:14 PM
AFjeepMan
I only have the RC 3.25" lift and I was closer to the max extension of the rear brake line as I was comfortable with. it's all up to you, but there is a reason that the stock brake line is a certain length (hint: it was made to operate at stock suspension height) and when you increase that with a lift it really is a should do to lengthen the brake lines front and rear between the frame and axle.
[_l_,[____],
l----L - OlllllllO-
(o)_) (o)_)--)_)
Wife≥Jeep>GF
post #15 of 38 Old 07-29-2010, 09:22 PM
Knuckelhead
AFSOC Retired
Show me where you need a longer rear brake line on the rear axle with a suspension lift? The rear brake line length doesn't change with a lift (short arm, OP) as it's routed along the upper control arm. You don't need one on the rear axle...
rear , coil , coils , coil spring , removal , replacement
Rear Coil Spring Advice maxruby TJ Wrangler Technical Forum 2 03-08-2010 11:32 AM
Help with rear coil spring pads TJ kooljp TJ Wrangler Technical Forum 7 10-18-2009 10:51 PM
OE front coil spring replacement rgrovogel TJ Wrangler Technical Forum 2 07-25-2008 01:37 PM
Anyone use Rear Coil Spring Retainers conor.davis TJ Wrangler Technical Forum 3 02-26-2007 10:01 PM
Front and Rear Coil Spring Tag #'s?? mkuzmukerau TJ Wrangler Technical Forum 3 11-15-2004 03:55 PM
