Rear coil spring relocation brackets? - JeepForum.com
post #1 of 30 Old 11-10-2010, 07:47 PM Thread Starter
JJeeper09
Relocation**
Im thinking about moving my rear coils back on the frame and my questions are what are good mounts to use. I have seen people re-use the stock coil bucket but im thinking ill mess it up so should get aftermarket. Any pictures with rear coil spring relocation brackets
JJeeper09 is offline
post #2 of 30 Old 11-10-2010, 07:50 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I used Ballistic's brackets when I did my stretch.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #3 of 30 Old 11-10-2010, 07:54 PM Thread Starter
JJeeper09
I just clicked on their site as your posted! Not a bad price at all
post #4 of 30 Old 11-10-2010, 07:59 PM
pcoplin
It's really quite easy to remove them with an angle grinder and dremel.
You can also buy the stock brackets from Jeep, too.
FullStack MotorSports
pcoplin is offline
post #5 of 30 Old 11-10-2010, 10:47 PM
wushaw
Rockin jeep
wushaw's Avatar
I used Clayton, no picts of diff installed yet.
wushaw is offline
post #6 of 30 Old 11-11-2010, 08:21 AM
JeepRocks86
Originally I was planning on reusing my factory brackets, but I came into problems with their removal. I was able to move the upper spring mounts back a little further than with the factory coil mounts.
For Sale:
post #7 of 30 Old 11-11-2010, 08:25 AM
Imped
Imped's Avatar
I mangled the stockers.
Here's what I used: Product Details
OlllllllO
IndyORV
Imped is offline
post #8 of 30 Old 11-11-2010, 08:34 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Do you by chance have a part #?
I looked through the parts manual and I couldn't find the upper coil buckets anywhere.
I don't think they are available separately.
Wheelin98TJ is offline
post #9 of 30 Old 11-11-2010, 08:42 AM
ricko836
I'm doing this to my jeep soon, I think I will just use the stockers and extend them down.
ricko836 is offline
post #10 of 30 Old 11-11-2010, 08:55 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
*click*
*click*
Mail crawling.
MisfitSeven is offline
post #11 of 30 Old 11-11-2010, 09:52 AM
glockster
re-used the stockers.
Marco
glockster is offline
post #12 of 30 Old 11-11-2010, 10:03 AM
pcoplin
Looking back through, ATXJZ used them on his original stretch. You can see the p/n for one of them here:
JeepsUnlimited.com Forums - View Single Post - Made some progress on the MidArm Project *PICS*
Hope that helps, I've never reused them. But then, I'm a surgeon with a grinder.
pcoplin is offline
post #13 of 30 Old 11-11-2010, 10:08 AM
Wheelin98TJ
JEEP FREAK
Thanks.
They are listed in the parts manual, I just missed them.
post #14 of 30 Old 11-11-2010, 06:17 PM
sduncan
sduncan's Avatar
I used these. Worked great.
http://www.superlift.com/media/bulletins/s185.pdf
'98 TJ, 5.7 HEMI,
sduncan is offline
post #15 of 30 Old 03-11-2011, 04:38 AM
frAnken_rubi
Sorry to bump an old thread, but does anyone know if the TNT one are worth it?
http://www.tntcustoms.com/Jeep-wrang...elocators.aspx
/l o[____]o
l---L --OlllllllO-
()_)-()_)-o-)_)
http://www.jeepforum.com/forum/f22/frankin_rubi-tj-build-1140219
frAnken_rubi is offline
Rear Coil Spring Advice maxruby TJ Wrangler Technical Forum 2 03-08-2010 10:32 AM
Help with rear coil spring pads TJ kooljp TJ Wrangler Technical Forum 7 10-18-2009 09:51 PM
Coil Spring Isolator for rear? UnsanePyro TJ Wrangler Technical Forum 5 11-01-2007 10:56 AM
Anyone use Rear Coil Spring Retainers conor.davis TJ Wrangler Technical Forum 3 02-26-2007 09:01 PM
Front and Rear Coil Spring Tag #'s?? mkuzmukerau TJ Wrangler Technical Forum 3 11-15-2004 02:55 PM
