Rear brake schematic - JeepForum.com
post #1 of 3 Old 07-31-2010, 03:23 PM Thread Starter
joburnet
I'm out of town and I need to get a schematic of the rear brakes on a 97 TJ with drum brakes and no ABS. It broke so I don't have a before pictures to look at, I have my tools but no book. I've replaced shoes before without a problem, what is the process of removing and replacing the wheel cylinder? Thanks.
joburnet is offline
post #2 of 3 Old 07-31-2010, 10:09 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Look at the opposite side brakes as your example. The brake cylinder has the hard brake line in the back, and two mounting bolts. If the hard brake line is stuck use a vise-grip and apply some heat with a propane torch. Bleed the brakes when you are done.
CJ7-Tim is offline
post #3 of 3 Old 07-31-2010, 10:11 PM
jose_p_adams
Remove the shoes first. You may be able to get away with just removing some of the springs. You just need to be able to get the shoes away from the cylinder so you can remove it.
Then remove the brake line from the back of the cylinder. Then there are 2 3/8" bolts in the area of the brake line that hold the cylinder on. The new cylinders bolt on the same way they came off. Then re-assemble and bleed the system.
I just did this today and it was a lot faster to type it.
jose_p_adams is offline
rear , brake , diagram , drum
Rear Disc Brake Conversion..now spongy brake pedal orange06tj TJ Wrangler Technical Forum 9 02-22-2012 07:36 PM
LJ Schematic tahoez58 TJ Wrangler Technical Forum 2 04-29-2010 07:50 PM
I need a rear Drum Schematic (sp?) for a Dana 35) off an 00 wrangler jooosooo TJ Wrangler Technical Forum 2 06-06-2008 03:30 PM
RE Rear Brake Line and E-Brake Cable Questions? Jeep4Rox TJ Wrangler Technical Forum 1 01-12-2006 03:42 PM
Rear brake hose broke and so did the rear control arm mount Saturdaynight YJ Wrangler Technical Forum 10 12-30-2003 08:30 AM
