Hi. I have a '00 Sahara 4.0 auto, 40k, stock. It suddenly started loosing coolant and got hot. I did a quick check and all I can see is that it appears to be dripping in the area of the flexplate inspection cover. I don't see anything wet anywhere else on the motor. Is there a freeze plug in the rear of the block under the bell housing? Any other suggestions? I really don't want to pull the motor just for the fun of it! Thx - Mike
My son was driving it, he said he first smelled coolant and later saw steam but didn't check it. Later he saw more steam and then it got hot. He added water to the overflow because it was empty, and drove it home 3 hours without issue. Overflow was a little low. (anyone want to adopt a 26 yr old idiot?)
You can pressure check coolant system, check compression, along with the spark plugs, check your oil for water contamination, check coolant for oil contamination! Sounds like a head gasket! You could check the rear freeze plug on drivers side to see if it is leaking! There are 5 of them underneath the manifolds.Good luck!
I have a block also in garage, but it's secured inside a covered pallet! I will look in back of block for another freeze plug tomorrow! I'm trying now to find it in the FSM! It doesn't show a 6th freeze plug behind flex plate! Sorry!
there is a plug in the back of the head. and 2 in the block. 1 for the cam 1 for coolant. it's within the area of the bell housing and opens to the cylinder / coolant area.
Dang never monday. Got some 4.0's just layin around do we? :laugh:
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
