Quantcast Rear axle and tires - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rear axle and tires
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 09-14-2004, 07:25 PM   #1
the_ronster
Rear axle and tires
Ok, I got on the jeep build page and found out that my 2003 Sport has a Dana 44 rear axle (is this normal from the factory?). The front is a 30, so my question is, how big of tires can I safely handle without having to replace the front? I am currently running 31's and was considering a 3 in suspension lift and maybe a 1 in body lift. This from what I have read here states that I should be able to run 33's. My only concern at this point is the front axle. I would rather not break anything if I can keep from it. Thanks for any advice!
the_ronster is offline   Reply With Quote
Old 09-14-2004, 08:10 PM   #2
penguinland
You'll find that alot of people run 35s on a d30 without issue. Replace it when you break it a few times but you'll be fine.
Bone Stock
penguinland is offline   Reply With Quote
Old 09-14-2004, 08:16 PM   #3
BigWaylon
tubework is cool...
BigWaylon's Avatar
you'll definitely be fine up to 35's...
the D30 is not the axle you hear complaints about...it's the D35 (which is the other rear option instead of the D44)...
just because the 44 is a bigger number (and stronger axle) than than 35, doesn't hold true that the 30 is even worse than the 35...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Glock Forum
