Rear axle shifted towards the drivers side, suggestions??? - Page 2 - JeepForum.com
post #16 of 22 Old 04-04-2012, 06:49 AM
Imped
Imped's Avatar
Your axle is still square to the frame, or at least as square as it came from the factory. It's just offset to the the side--think parallelogram. You'll want an adjustable track bar that can be adjusted a bit shorter than stock to 'pull' your axle back over. That's pretty odd and it means that you were even more offset before adding taller springs.
OlllllllO
IndyORV
Imped is offline
post #17 of 22 Old 04-04-2012, 06:53 AM
mdm
Farm Wheeler
There are +/- allowable tolerances in manufacturing. Sounds like everything ganged up to make the axle sit to the left. It's hard to believe it was that far off though.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #18 of 22 Old 04-04-2012, 06:54 AM
Umbra0101
Could have been in an accident that bent the frame a tad.
Last night, my girl started smoking, so I slowed down and lubed her up a little.
Umbra0101 is offline
post #19 of 22 Old 04-04-2012, 09:02 AM
OiCaesar
I just dealt with this on my rig, it took a combination of getting the trackbar, and control arms aligned. Adjustable trackbars and control arms are your friend. Don't take it to a cheapo alignment shop, they will only check Toe-in. ensure they do a front and rear alignment, an untrained mechanic will go by what the machine says only instead of breaking out the proper tools and gauges to set the axle straight. Good luck
OiCaesar is offline
post #20 of 22 Old 04-04-2012, 10:45 AM
chubbena
the jeep is begging for a higher lift?
chubbena is offline
post #21 of 22 Old 04-04-2012, 11:27 AM
gcinque
The thought of the accident did cross my mind....... the carfax was clean.
Maybe a lift will help...
Thanks for all the suggestions I'll let you know how it goes.
gcinque is offline
post #22 of 22 Old 04-04-2012, 11:41 AM
mdm
Farm Wheeler
Originally Posted by gcinque View Post
...the carfax was clean. ...
CARFAX is only as good as the information that is fed into it. I do all my own work. How much of what I've done to my rig, or why, do you think will show up in a CARFAX report?
CARFAX is a classic case of GIGO.
mdm is offline
rear , axle , centering , shifted , tj , wrangler
Dana 44 Axle Shifted 1 1/2 inch to the drivers side jazzman31 TJ Wrangler Technical Forum 13 10-25-2009 10:36 AM
Dana 44 Swap Shifted Towards Drivers Side jazzman31 TJ Wrangler Technical Forum 13 09-21-2009 12:10 PM
Chick with a LJ needs liftkit help! Rear axle pulling to drivers side! JSB TJ Wrangler Technical Forum 31 05-01-2009 11:43 AM
Front axle is shifted over to passenger side CaliforniaKid TJ Wrangler Technical Forum 15 04-08-2008 08:08 AM
Why is my swaybar shifted to the drivers side??? thejafe TJ Wrangler Technical Forum 6 10-29-2005 08:42 PM
