Rear adjustable track bars. - JeepForum.com
post #1 of 4 Old 04-01-2008, 01:12 PM Thread Starter
chutta
Are there any that curve forward at the passenger/axle mount side so as to not hit the tank skid caused by axle rotation back for pinion alignment?
Mine's been rubbing against this for some time and has to be transmitting shock to the frame, not to mention restricting movement.
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #2 of 4 Old 04-01-2008, 01:29 PM
Crashnburn80
Crashnburn80's Avatar
This is due to your 4" lift + TT, your axle is rotated way back for proper pinion angle. You need a CV trackbar bracket to rotate your mounting point forward in addition to your adjustable trackbar. Also, many aftermarket gastank skids such as Rokmen, Kilby and EMP are redesigned to allow additional trackbar clearance to avoid this problem.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #3 of 4 Old 04-01-2008, 01:55 PM Thread Starter
chutta
I was hoping for a one piece solution to rid my setup of bolt on brackets that come loose.
chutta is offline
post #4 of 4 Old 04-01-2008, 03:58 PM
VinoTJ
VinoTJ's Avatar
I have the Rokmen gas skid, the JKS track bar and the JKS CV bracket mount along with a TT and 2.5" suspension lift - no rubbing.
Use loctite if you are concerned about loose bolts.
2008 Wrangler Unlimited X
VinoTJ is offline
how important are front and rear adjustable track bars? travk1234 TJ Wrangler Technical Forum 5 09-02-2009 09:01 AM
Adjustable track bars Aiden80013 TJ Wrangler Technical Forum 8 05-17-2009 04:07 PM
adjustable track bars jr1966 TJ Wrangler Technical Forum 2 03-17-2008 05:15 AM
adjustable rear track bars UTmike TJ Wrangler Technical Forum 18 12-31-2007 11:24 AM
Best Adjustable track bars kaybone TJ Wrangler Technical Forum 2 02-24-2005 07:15 PM
