Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Wild Boar Products Cargo Rack or Front Bumper Giveaway
Go Back   JeepForum.com > Models > Wrangler Forums Group > TJ Technical Forum
Register FAQ Search Today's Posts Mark Forums Read Search Members
Old08-23-2008, 01:21 PM #1
Pionex311
roamer of the lands
Really quick S35 question
Hi guys. I know that there are a lot of threads out there about this but all those threads are laden with arguments from guys using different setups. Well, to avoid all that, I wanted to ask a straight forward question. What do I need to buy when I buy the Superior S35 upgrade kit with the ARB locker? I already know that I need an air compressor, which I already have lined up and ready to buy, but what else do I need. I plan on getting the Superior line of 4.88 gears to round off the setup. Also, I'm going to take it into a shop to get it done because I lack the know how to do this. Do I need to buy shims? I guess the best way to do this is by having someone make up a shopping list real quick to point me in the right direction. All help would be appreciated.
Pionex311 is offline   Reply With Quote
Old08-23-2008, 01:25 PM #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
The ARB case will need to be shimmed left/right to set the backlash between the ring & pinion gear but the shop setting it up for you should provide that kind of stuff. Hopefully you're buying the ARB compressor "kit" which will make getting that side of things working extremely easy. The Super 35 kit includes bearings etc. so you really won't need much, if anything, beyond what you have. Just make sure the installing shop uses Locktite on the ring gear bolts to prevent them from backing out in the future and causing a catastrophic failure.
See the Geezer Jeep at http://members.cox.net/jerrypb/
Getting Savvy...
Jerry Bransford is offline   Reply With Quote
Old08-23-2008, 01:41 PM #3
Pionex311
roamer of the lands
Thanks Jerry for the quick reply. I am going to buy a ARB compressor but that brings up another question...do I have to buy the kit or can I just simply go straight into the high output compressor that they offer. I wanted to have a compressor that can activate the locker and be used as a source of air for inflating my tires when I'm ready to hit the road. If I need to buy the kit, then I will do that and probably get a second source of air for the inflation issue.
Old08-23-2008, 03:18 PM #4
Jerry Bransford
I would not use the ARB compressor as a source of air for your tires, even with the bigger size. And then, not even ARB's larger compressor puts out much air volume so it will still be slow to fill up your tires. I'd go with their standard compressor and make that a stand-alone source of air for your lockers and have something else for use for airing up your tires.
Also, resist any temptation to go with ARB's heavy-duty air hose, go with the standard air hose. If the heavy-duty air hose ever gets snagged, it's strong enough to yank out a critical fitting that you likely couldn't repair on the trail. The standard duty air hose is very strong, yet it is designed to 'snap' if it every gets snagged which presents you with an easy fix that takes maybe 10 seconds with ARB's quick splice repair kit. But so long as your ARB installer knows what he is doing, he'll route the air line so it is well out of the way of any danger of ever getting snagged.
Getting Savvy...
Old08-23-2008, 03:29 PM #5
Pionex311
roamer of the lands
Awesome, thanks for the info. One last thing, what would you recommend as a good decent for airing up my tires?
Old08-23-2008, 09:49 PM #6
elkfan2
elkfan2's Avatar
I bought one of viairs portable compressors cant remember exactly which one but it was the bigger one and i can air up all 4 of my 35x13.50r15's in a little less than 10 minutes. I agree with jerry about buying the smaller compressor and using it for locker duty only.
2002 TJ 4.0 Litre, 5spd, 6" Fab Tech long arm, 35x13.50r15 Toyo MT's, 15x8 Soft 8's, Dana 44 with ARB, Dana 30 Detroit locker, 4.88 gears, Smittybuilt SRC front and rear bumpers, Line-x interior, T-max 10,000 lb integrated series winch, ORO lite dots, Rubicon Express hand throttle, Flowmaster exhaust, Currie anti-rock swaybar, Dodge Durango steering gear box. Grand Cheerokee tie-rod. 4spd Atlas T-case. Clayton Adjustable control arms.
elkfan2 is offline   Reply With Quote
Old08-24-2008, 02:14 AM #7
Greg_Volkman
personally i plan to run my ARB off the 2.5g Sun Performance tank I have under the jeep (filled by my ViAir). rather than listen to ARB's dinky little compressor cycle on/off all day I figured i'd buy a step-down kit to run the lockers off my pre-exhisting OBA.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Old08-24-2008, 12:28 PM #8
Jerry Bransford
Unless you have an air leak, the compressor won't cycle on and off all day Greg. ARB's "dinky little compressor" is actually ideal for the ARB Air Locker application because it only requires an extremely small volume of air to engage their locker. The pressure ARB's locker requires is quickly achieved in the small air space presented to the compressor by the air locker and its air line.
Getting Savvy...
Old08-24-2008, 01:22 PM #9
Jeepster83
Send a message via Yahoo to Jeepster83
i dont know if it was some kind of promotional deal but when my girlfriend got her S35 with the ARB the compressor was added at no charger. we were at 4 wheel parts here in sacramento. i do know one of the guys pretty well and get good deals fairly often but when i got the ARB kit i wasnt working with him. it may be worth it, and it never hurts, to ask.
If blind people wear those really big dark sunglasses, why don't deaf people wear earmuffs?
KEEP JV OPEN <----click that
Sacramento Jeeper #11
Jeepster83 is online now   Reply With Quote
Old08-24-2008, 01:30 PM #10
elkfan2
elkfan2's Avatar
When I engauge my ARB airlocker wth the "dinky little compressor" it cycles once for about 5 secconds to to engauge the locker then I dont hear it again, if its cycling more than that then obviously you have an air leak to fix.
Old08-24-2008, 01:59 PM #11
Greg_Volkman
no, but if you guys leave your lockers engaged all day long you drive a bit differently than me....specially in the front it's not uncommon to disengage the locker to make tight turns. in snow, both lockers when on sidehills, too.
at any rate, having onboard air already, it was less expensive to buy the kit to run it off the tank.
-0|||||||0-
Old08-24-2008, 02:06 PM #12
elkfan2
elkfan2's Avatar
No i only use mine when i need it then disengage it but with my compressor mounted under the hood i dont hear it enough to cause concern, but if i was wheeling in somewhere that i was constantly turning it on and off yes then yes a setup like you described would be nice.
Old08-24-2008, 02:20 PM #13
ohtenwillys
Send a message via AIM to ohtenwillys
wow.. if youre paying a shop.. you might as well pull a big bearing 9inch from a junkyard and have them plop that in... super 35s are just bandaids for silly problems that you could just avoid by getting a stronger axle
plus chicks dig ford axles
ohtenwillys is offline   Reply With Quote
Old08-24-2008, 02:27 PM #14
Greg_Volkman
oh god, here we go, and please note - it wasn't me :-)
i'm out.
-0|||||||0-
Old08-24-2008, 02:30 PM #15
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
Send a message via AIM to SlinkyTJ Send a message via Yahoo to SlinkyTJ
Sure, if you like having different width axles and different bolt patterns front and rear. Of course all that can be changed, but that adds more to the price. Super35s aren't all that bad depending on the intended use. For a small lighter jeep they can hold up just fine. Mine lives on even following Kelso around.
'97 SE
Lockers and stuff
SlinkyTJ is offline   Reply With Quote
pilot bushing - quick question/hope for quick answer Smash209 YJ Technical Forum 5 06-15-2008 10:18 PM
Quick quick disco question brew461 TJ Technical Forum 3 03-28-2008 10:20 PM
Quick Skid Question Need Help QUICK NikVallens TJ Technical Forum 7 04-15-2007 03:13 PM
Quick question, quick answer bman9089 TJ Technical Forum 3 03-04-2007 02:02 PM
Quick Simple Question lookin for quick simple answer 97GreenTJ TJ Technical Forum 19 12-22-2006 04:12 PM
The time now is 02:12 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
