Really need some help with lift and TC drop issues - JeepForum.com
post #1 of 5 Old 07-19-2010, 08:18 PM Thread Starter
b912
Hey guys, been lurking for a few months now and tried to weigh in where I could but now its time to post for some help. I bought a garage kept 98 Sahara with 65K from a 90yr old man three months ago and let me just say, boy was I fooled. I can't imagine what that old guy did, but it's got to be the hardest 65K I've ever seen on a vehicle. Most recently, I had to replace the rear end so while it was out, I had my 2.25" BB lift and shocks installed. Afterwards, my driveshaft would vibrate on acceleration up through about 3rd gear. I bought the skyjacker TC drop kit from a local 4x4 shop today and just finished the install. It was the 1" kit for 2.5" lifts. It seems to have corrected the vibrations, but now 2nd, 4th, and reverse don't feel like they're going in all the way. They work, but it's definitely not right. I did have an issue following their instructions to install the transfer case pivot linkage drop bracket. It just didn't fit. I have a few questions that I'm hoping you guys could help me answer.
1. I ended up not using the pivot linkage drop bracket because it didn't fit right. From my searching on here, you can accomplish what the drop kit does with some washers and longer bolts so it seems to me, this bracket is not really required. Is that true?
2. What is the remedy for the shifting issue post TC drop?
3. Does the fact that I'm not using the pivot linkage drop bracket have anything to do with my shifting issues in 2nd, 4th, and reverse?
I'm really at a loss here and appreciate any help you could provide. Thanks.
b912 is offline
post #2 of 5 Old 07-19-2010, 08:56 PM
WV-TJ
The most simple fix for the shifter is to remove it from the transmission via one torx bolt. Just pop the boot and surround loose from the consol and slip the plastic cover from the bottom of the shifter.You will then see the bolt. Take the shifter out, put it in a vice, heat it with a torch and bend it slightly forward. For the transfer case bracket, I had to take the two bolts loose that hold the shifter bracket to the transfer case. The two 10mm bolts can be removed from the bracket bolted to the tub and then you can easily install the new bracket. As far as the transfer case drop goes you can use flat washer, just add a few between the skid and the frame. If you still have vibes, add another washer or two in each location. Repeat these steps and test drive til the vibes are gone.
WV-TJ is offline
post #3 of 5 Old 07-19-2010, 09:18 PM Thread Starter
b912
Thanks for the reply. That's a pretty simple fix for the shifting issue. For the pivot drop bracket, is it absolutely necessary? I've eliminated the vibrations by adding the 1" spacers between the frame and the skid plate.
b912 is offline
post #4 of 5 Old 07-19-2010, 09:22 PM
04_Sahara_Man
This might help Under Cover Fabworks, LLC - UCF LOPRO Transmission Mount
Currently 04 Sahara: 3" BDS lift, 9500 BDS Monotubes, Flowmaster Super 44, Olympic Rocker Guards, 33" Duratracs, 15x8 Black Rock Blades.
Khaki Jeep Club Member
In Pennsylvania, fun is illegal
Xbox live GT - TheExecutive00
Tama, Paiste, DW, Zildjian, Vic Firth....yes I go boom boom!
04_Sahara_Man is offline
post #5 of 5 Old 07-19-2010, 09:31 PM
WV-TJ
Just try your transfer case shifter and make sure it will make it into 4-lo. If it does and you have no binding, you should be ok.
WV-TJ is offline
lift , t-case , t case , drop , transfer case , suspension , help , issue , TJ
Anyone run a RC lift with 1/2" lift boomerang shackles and only TC drop? MA88XJDude YJ Wrangler Technical Forum 11 04-11-2010 07:43 PM
ARG! TC Drop = Clutch issues? Huh? Roadhawg TJ Wrangler Technical Forum 0 06-08-2009 12:16 AM
Second gear issues... Is the TC drop the problem? 94YJEEPER TJ Wrangler Technical Forum 4 01-30-2009 04:39 PM
Motor mount lift, trans drop, tranny rebuild issues Hawk37 YJ Wrangler Technical Forum 0 01-22-2009 09:31 PM
Drop pitman arm with a TJ, clearance issues! lwoods TJ Wrangler Technical Forum 19 07-10-2006 12:18 PM
