Really Bad Gas Mileage! - JeepForum.com
post #1 of 21 Old 01-12-2012, 12:43 PM Thread Starter
neddevine
G'day, new to jeeping, love it except the gas mileage is beyond ridiculous. I know and was expecting bad mpg on a 160,000 mile 1997 2.5L but 8 yes 8 mpg is just wrong. Tires are 30x9.5x15
I am going to change: front and back o2 sensors, injectors, coolant temp sensor, tune up etc. Compression test will also be taken.
There are no codes to review. No vacuum leaks.
Engine runs good, starts right up, has power with no missing.
I need real help please, no I won't sell it!
Any practical input truly appreciated.
Thanks in advance
neddevine is offline
post #2 of 21 Old 01-12-2012, 12:54 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I'd start with plugs,wires,distibutor cap.My 2.5L on 31's had 200,000 miles on it and always got around 15 mpg city.
TheBoogieman is offline
post #3 of 21 Old 01-12-2012, 01:14 PM
canyon
It could be a small crack in exhaust header? Just throwing it out there.
canyon is offline
post #4 of 21 Old 01-12-2012, 01:16 PM
mdm
Farm Wheeler
O2 sensor?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #5 of 21 Old 01-12-2012, 01:41 PM
Dextreme
You are talking highway/city mpg correct? Because I get about 8mpg gallon in 4 low.
'99 Chilli Pepper TJ Wrangler -- "Mistress"
Zone 4.25"
33" GY Duratrac's
Dextreme is offline
post #6 of 21 Old 01-12-2012, 02:29 PM
vtx531
How are you calculating this?
vtx531 is offline
post #7 of 21 Old 01-12-2012, 04:46 PM
4banged
LMAO
Seriously though, I only get about 14mpg in mixed driving with my 03 2.4l 4 speed auto 31" tires. I've done the wires, plugs etc and have considered replacing the O2 sensors so let us know what you find to be the culprit.
4banged is offline
post #8 of 21 Old 01-12-2012, 04:51 PM
94yjstocklook
8mpg definitely sucks. On my 94 4.0 6 cyl. i get roughly 13/15mpg. Sorry for no help but definitely something going on.
94yjstocklook is offline
post #9 of 21 Old 01-12-2012, 05:26 PM
Jim Shanks
Jim Shanks's Avatar
My last few fills with my 4.0 has netted around 7-8mpg. I'm looking into a diesel powerplant for the TJ.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #10 of 21 Old 01-12-2012, 06:37 PM
1999TJRED85000
I think everyone hit the major things you can check. The first thing I thought was Oxygen sensor. If your sensors are off, the CPU will think things are happening that aren't and bad mileage is usually the immediate result. Plug wires and plugs might hurt a little, but it would have to be running really rough to get that poor of mileage. If you're a mechanical type, give it a full tune up with new wires, OEM plugs, dist. cap, air filter, oil and oil filter change, etc. In other words, do all the cheap stuff that should be done anyway. Oxygen sensors aren't that expensive either, but if you aren't familiar with how they work, take it to a local wrench.
Hope this helps.
F U
1999TJRED85000 is offline
post #11 of 21 Old 01-12-2012, 06:57 PM
silver97tj
silver97tj's Avatar
Hi all lets be honest anything for a jeep tj in the range of 12 -14 mpg is good, anything over 17 is not reality. This is a jeep not a honda civic!.............just do tune up, and change O2 sensor and check cats. etc etc, most of this is do it yourself, pretty easy................
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #12 of 21 Old 01-12-2012, 07:04 PM
biffgnar
biffgnar's Avatar
Being honest 14 is not good for me. 14 is a disappointing tank.
biffgnar is offline
post #13 of 21 Old 01-12-2012, 07:26 PM
Dorian772
that made me laugh
Dorian772 is offline
post #14 of 21 Old 01-12-2012, 07:52 PM
catsknr
Dont forget to check the thermostat, if stuck open it will run too cool and comp. will feed it rich to try to warm up.
/l ,[____],
l-L -OlllllllO-
()_)-()_)-o-)_)
Just Empty Every Pocket
catsknr is offline
post #15 of 21 Old 01-12-2012, 08:26 PM Thread Starter
neddevine
Thanks for all the input.
Filled tank then ran until quarter full then refilled 12 gallons and 97 miles.
Second tank half full 8 gallon 63 miles. Mix of city and hwy driving in 2 wd not 4 low! Thermostat works fine.
Thanks to all for input. I will, over next few days change parts, test and report back.
Gas mileage seems a bit low bgradisar TJ Wrangler Technical Forum 17 05-10-2011 10:49 PM
Vibration, Bad Mileage, Very Bad Mileage Harley_Jeep_Man TJ Wrangler Technical Forum 10 09-04-2010 06:55 PM
Bad Mileage.. even for a YJ. LoS10 YJ Wrangler Technical Forum 5 01-31-2008 10:12 PM
help with gas mileage baller88 TJ Wrangler Technical Forum 6 03-02-2005 08:05 PM
Gas mileage tj01wrangler TJ Wrangler Technical Forum 21 02-27-2005 03:32 AM
