RE Long Arm -> Front Track Bar Bracket hit Tie Rod? - JeepForum.com
post #1 of 37 Old 04-23-2008, 12:27 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
Has anyone with a Rubicon Express Long Arm Kit had the Front Track Bar Bracket (Top/Drivers side) make contact with the Tie Rod?
I'll try to get a pic this evening, but after a recent trip to Pismo Beach for some dune wheeling, I noticed just a "slight" bend way up high on the drivers side of my Track Bar (OEM still till I get some $$$ for a Currie HD Setup). I didn't think much of it because it was pretty minor and I didn't feel any difference in the steering or anything. It could have been from one of other trips, but haven't done anything crazy recently (Hollister hills a couple months ago and a Snow run up in the Sierra's in February)
I looked a little closer today and there are two little marks on the Tie Rod that correspond to a direct line to little flat spot the lower side of the Upper Track Bar mounting bracket... was pretty obvious that at some point the two made contact at some point, maybe a couple times, and at least hard enough to put a VERY slight tweak in the Tin-Foil OEM Tie rod...
Is that "normal" and anything I need to be worried about, or should I just go wheel the crap out of it so I can bend it bad and have the justification to upgrade?
SW2
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #2 of 37 Old 04-23-2008, 01:46 PM
imbezol
imbezol's Avatar
I've seen those marks near the driver's side of my tie rod as well. I was sure that it was from the tie rod making contact with the brackets for the bottom spring perch though. Here are two pics to illustrate.. you'll notice that the drop bracket for the trackbar sits oriented sideways and couldn't really make those marks. In the second pic you'll see the two brackets going down from the spring perch that are narrower (sharper) and could definitely make the marks. I think it happened when something pushed the flimsy tie rod in towards the axle, and possibly I was turned hard to the left.
Note that there are no marks yet in these pics as I had just installed the lift.
imbezol is offline
post #3 of 37 Old 04-23-2008, 02:06 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Is your front driver-side tire stuffing too high up into the wheel well? Do you have the correct height bump stops installed?
Jerry Bransford is offline
post #4 of 37 Old 04-23-2008, 02:08 PM Thread Starter
SuperWade2
SuperWade2's Avatar
You'll have to excuse the low res cell phone pics, but it shows the bend, and the two Rubicon Express "Grey" Paint markings on the Tie Rod that look more likely to have hit the lower edge of the Track Bar Joint where it ties into the drop bracket.
2017 WK2 Overland
post #5 of 37 Old 04-23-2008, 02:09 PM Thread Starter
SuperWade2
SuperWade2's Avatar
I dunno.. I have whatever stops came with the 4.5" RE Tri-Link Long Arm kit as far as I know... I didn't install it... I had it done...
SW2
2017 WK2 Overland
post #6 of 37 Old 04-23-2008, 02:11 PM
Jerry Bransford
Administrator
SW2
I'd check it out further then, I can't think of any other reason the tie rod could come in contact with the upper trackbar bracket.
post #7 of 37 Old 04-23-2008, 02:15 PM
imbezol
imbezol's Avatar
That's odd. I can stuff my driver's side all the way up and it's nowhere close.
imbezol is offline
post #8 of 37 Old 04-23-2008, 02:20 PM Thread Starter
SuperWade2
SuperWade2's Avatar
It looks like that kit should have shipped with the 2" Lower Bumpstops for the front (vs the 3" Fronts that come with the 5.5" Kit)..
I'll go see what I can see...
SW2
2017 WK2 Overland
post #9 of 37 Old 04-23-2008, 02:29 PM Thread Starter
SuperWade2
SuperWade2's Avatar
This is the only semi-Full Stuff Pic that I have and it's pretty dark, and not a great angle to see the underside... It "looks" like the Tie Rod is still straight as far as I can tell... Only did the Snow Run and Pismo since this was taken, and no big "stuffs" as far as I remember...
2017 WK2 Overland
post #10 of 37 Old 04-23-2008, 02:32 PM
imbezol
imbezol's Avatar
When I had it flexed there I took a look and had about 2 or 3 inches to go before my bumpstops bottomed out but I still don't think it'd get the tie rod up that high. Myself I'm building a Waggy 44 front with high steer to get away from all these weirdnesses (and make some new ones probably). I have problems with my tie rod hitting my lower stabilizer shock bolt. Anyways, good luck figuring it out and let us know how ya fixed it.
Edit: love the look of your Jeep! Nice rig!
imbezol is offline
post #11 of 37 Old 04-23-2008, 05:46 PM
Lawrence
That's easy to figure out. Measure the distance between the tie rod and the bracket and then between the upper and lower bumstops. If the former is greater, it will hit.
SW2
It’s not normal, and if you don’t address it, you’ll keep bending the tie rod. I recently redid my suspension and ran into this problem big time. I didn’t want to fiddle fart with it, so off with the RE, in with the Currie. If you don’t want to change it, there may be a solution.
I had to redrill the RE bracket about 1/2” higher to “raise” the trackbar and make it as parallel as I could with the draglink. This would have allowed me to shorten the bracket if I wanted to. Look to see if your trackbar and draglink are parallel, if not and you need to move the trackbar up, that may be your solution.
Lawrence is offline
post #12 of 37 Old 04-23-2008, 07:45 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Right @ 5 inches Between Tie Rod and Lowest Part of the Upper Track bar (actually the track bar near the zerk not the bracket I think)
~8 inches between the Upper and Lower Bumpstops inside the shocks...
And here is the best I could do for a full view...
2017 WK2 Overland
post #13 of 37 Old 04-23-2008, 08:31 PM
Lawrence
Well, that's your problem.... Either add more bumpstop or get another trackbar. Those are your two options.
Unless, judging from that last picture, you keep on hitting your tie rod and let it clearance itself. Best is to go to Pismo and get some serious air, guaranteed to work.
Lawrence is offline
post #14 of 37 Old 04-23-2008, 08:45 PM
Gold03TJ
Gold03TJ's Avatar
Can you get a closer pic of the upper bumpstop in your coil? Almost looks like the cup that bolts in and the rubber bumpstop are missing off the top.
03 INCA GOLD
My pics
Gold03TJ is offline
post #15 of 37 Old 04-23-2008, 09:14 PM Thread Starter
SuperWade2
SuperWade2's Avatar
So the Adjustable Trackbar/Drop Bracket that they sell with the kit, with their Shocks, Springs and Bumpstops (part of the same kit) aren't designed to work together??? That doesn't sound right at all...
Gold03TJ, I'll try to get a closer pic of the upper bumpstop... I have to go move the heep into the Driveway anyhow...
2017 WK2 Overland
Broken front track bar bracket unlimited4x4 TJ Wrangler Technical Forum 23 04-23-2016 01:43 AM
Redrilling front track bar bracket after lift ROLLTIDEtj TJ Wrangler Technical Forum 3 06-19-2009 06:06 AM
front track bar bracket loose westmichjeeper TJ Wrangler Technical Forum 6 02-22-2009 02:23 PM
Front track bar bracket YellowNJTJ02 TJ Wrangler Technical Forum 1 08-16-2006 07:57 AM
Front Track Bar & Rear Track Bar Bracket mossimo19 TJ Wrangler Technical Forum 4 09-14-2005 07:56 PM
