RE Lift questions for an LJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > RE Lift questions for an LJ
New Knuckles Skid Plate at JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker Purcha
Unread 03-30-2006, 02:24 PM   #1
snowjoker
a few questions about the RE Suspension kits for my LJ. I am shooting for 33s
What makes the 3.5 superflex kit worth the $300 more than the Standard kit? Is it because it comes with the Adjustable track bars?
What are the advantages of the Adjustable trackbars? I am on somewhat of a budget, would the RE Standard Kit still be a good kit without the Adjustable track bars? Then I could add those later?
Also I have heard that the OME shocks give a better ride. What is your opinion on that?
This is still my DD so I don't want the ride to change too much....
05 Unlimited, Auto, Khaki, Dual Tops, RE 3.5" Super Flex lift, 33/12.50/15 Mickey Thompson Baja MTZ, 15x8 ProComp Extreme Alloy 1069 Wheels
My Ride:http://i12.photobucket.com/albums/a2...r/DSC02061.jpg
My trunk Box:
http://www.jeepforum.com/forum/f9/home-made-security-box-unlimited-thoughts-178930/
snowjoker is offline   Reply With Quote
Unread 03-30-2006, 02:43 PM   #2
BlueFlame
Looks to me like the difference is lower control arms with superflex joints and the front swaybar disconnects, and IMO those arms are worth having. Adjustable track bars can be avoided with relocation brackets.
http://www.rubiconexpress.com/dynami...?folderid=1601
BlueFlame is offline   Reply With Quote
Unread 03-30-2006, 06:09 PM   #3
RockPaws
The standard kit is a ok kit, but its very limited. The upgrade to the SuperFlex allows more preset adjustment and axle flex. By added adjustable track bars front and rear: you can center the axles properly. Also adding a set of adjustable control arms, the front caster angle and rear pinion angles can be adjusted. On my suspension, I opted for the 4.5 SF kit with upgrades for adjustable track bars and control arms, and subsutited the springs to 3.5"
I've installed a number of these lifts and I can tell you its well worth the upgrade if you can afford the extra $$.
[FONT=Trebuchet MS]01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
[URL=http://www.redrock4x4.com][COLOR=Blue]www.redrock4x4.com Rocks![/COLOR][/URL]
[URL=www.needhim.org/][COLOR=Blue]Need Him?[/COLOR][/URL][/FONT]
RockPaws is offline   Reply With Quote
