Re-Gearing - JeepForum.com
post #1 of 93 Old 03-09-2010, 09:01 AM Thread Starter
WillysGSR
Re-Gearing
I just put 31ís on and I noticed a drop in power. I use my Jeep as a daily driver and off-road frequently. I was wondering what would be a good gear ratio. Is that something thatís difficult to do your self or would it be best to take it to a shop? Thanks in advance.
WillysGSR is offline
post #2 of 93 Old 03-09-2010, 09:22 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
4.56 would work well with your auto tranny and 31" tires.
You would turn about 2,500 RPM at 70 MPH which is just about perfect.
You already have 3.73, so regearing to 4.10 would not be a big enough change to be worth it.
As for the installation, most people leave this job to the pros.
Wheelin98TJ is offline
post #3 of 93 Old 03-09-2010, 09:23 AM
admdonitz
You should take it to a shop, but why would you regear for 31's?
admdonitz is offline
post #4 of 93 Old 03-09-2010, 10:27 AM
MO2500
Off topic, did you swap in a NV241 from a rubicon?
As for re-gearing, If you don't have an experienced buddy or someone who has done them before to help you on your first gear install i'd recommend leaving it to the professionals. Re-gearing takes special tools, knowledge and a lot of patience to do correctly. Things have to be setup within .001" of spec to ensure you don't mess up your new gears and bearings.
Here's a good thread that been posted recently by Flatlander757 to show what's involved in gear set-up Re-gear thread
Another good article Billavista Gear article
Instagram: @omsmike
MO2500 is offline
post #5 of 93 Old 03-09-2010, 10:41 AM
dualtjs
2011 JK Wrangler
He's got a 3.07, so a bump to 3.73 would suffice for 31"s (7% jump in tire from 29" off set by a 21% jump in gearing). He could get that via a simple axle swap from a salvage yd (or someone upgrading to different axles).
Not to start an argument, but if he did have 3.73's, 4.56 seems excessive, for 31" tires. I would think that 4.10 would be a more appropriate choice.
dualtjs is offline
post #6 of 93 Old 03-09-2010, 11:14 AM
Imped
Imped's Avatar
With your transmission, go straight to 4.88. No reason not to with the excessively tall .69 OD.
OlllllllO
IndyORV
Imped is offline
post #7 of 93 Old 03-09-2010, 11:28 AM
Ktjex
I'm also interested, as I also have an auto with some loss of power after 31s and 3.73 gears. It's not terrible, but definitely could be improved.
So....4.10, 4.56, or 4.88???
What would rpms be like at 70 with the 4.88?
Ktjex is offline
post #8 of 93 Old 03-09-2010, 11:42 AM
Wheelin98TJ
JEEP FREAK
I just checked the profile and noticed the 3.07 gear ratio. That is probably incorrect.
All non-Rubicon TJs with the 4.0 and the 4 speed auto are supposed to have 3.73 gears.
4.56 may seem excessive for 31" tires, but not when you consider the OD ratio and the RPM numbers I posted previously.
post #9 of 93 Old 03-09-2010, 11:42 AM
dualtjs
2011 JK Wrangler
With 31's & 4.88's you would have to run 2560 rpm to hit 70. With stock 29's and 3.73 gearing, you needed 1950. While I understand the need to deal with the addition weight of the larger tires, that's a HUGE jump.
dualtjs is offline
post #10 of 93 Old 03-09-2010, 11:44 AM
Wheelin98TJ
JEEP FREAK
3.73 to 4.10 is not a big enough change to bother with.
4.88 will turn about 200 more RPM at 70 vs. 4.56, so you would be around 2,700 RPM at 70 MPH with 31" tires.
post #11 of 93 Old 03-09-2010, 12:05 PM
dualtjs
2011 JK Wrangler
Unless all he wants to do is gain back the drop off from going to 31's (i.e, basically zero intention of going taller on the tire) AND can find a cheap set of 4.10's out a 4 cyl. They would be straight bolt in for minimal cost and he could then sell his 3.73's for close to the cost of the 4.10's. There are a lot if "if's" in that statement, but if he got lucky, he could do the install himself, for something in the neighborhood of the cost of gears for 1 axle.
dualtjs is offline
post #12 of 93 Old 03-09-2010, 12:20 PM
iawia
I'm very interested in this too as I want to change to either 30's or 31's, preferably the latter, but I'm concerned about power loss as the OP mentioned.
I have a stock 4.0l TJ which does come with 3.07 gears so an increase to 3.73 or 4.10 would seem to be enough. The 4.10 from a 4 cyl seems like a good idea and likely easier to find than the 3.73, although that's what I have in my truck and would prefer.
This question has answered a question I was just about to ask in a new post. I know 31's will fit in a stock TJ, maybe with a bit of rub, but are they too big for the 3.07 axle? The answer seems to be yes.
I hope the OP won't mind if i ask a related question which is probably now moot: Will 10.5 tires fit on the stock 15x7 rims or are 15x8's needed?
If you regear, don't you have to do both front and rear axles?
iawia is offline
post #13 of 93 Old 03-09-2010, 12:23 PM
iawia
I forgot to mention in my previous post that there is a thread here on doing a regear by yourself.
http://www.jeepforum.com/forum/f9/ex...thread-965764/
iawia is offline
post #14 of 93 Old 03-09-2010, 12:56 PM
dualtjs
2011 JK Wrangler
31X10.50's will fit stock wheels without a prob. You'll probably need a washer or two on the steering stop, but it's unlikely that you will notice a difference in steering radius.
I have a manual, so performance with auto would be a little different. There is a noticeable change in the performance, from a power perspective, but I can also say that I saw a jump in mpg (I'll be giving it back when I do an axle swap, because I want a little more power performance when wheelin'). As far as wheeling is concerned, I haven't done any hard core hill or rock climbing and haven't had any probs keeping up when trail riding. I performance could be better, from an available power perspective and I end up riding the clutch more than I'd like. If I were staying at 31", I would probably just buy some used axles with 3.73's and put them in. I'll buy some 4.10's when I go to 33's. 4.56 would provide more wheelin power, but I can't afford to have to run the rpm to 2,600 to do 70 on Atlanta freeways (around here, you'd get run over if you went any slower).
dualtjs is offline
post #15 of 93 Old 03-09-2010, 01:24 PM
iawia
Thanks, dualtjs. I remember the freeways around Atlanta when I did some consulting in Kennesaw years ago. Also got a chance to see red Georgia mud.
iawia is offline
Swapping a 30/35 with 3.07 gearing for a 30/35 with 4.10 gearing...? Erik T. TJ Wrangler Technical Forum 13 10-02-2006 09:58 PM
YJ gearing JeepJeep80 YJ Wrangler Technical Forum 13 05-07-2006 07:40 AM
TJ SE Gearing? rab3t TJ Wrangler Technical Forum 8 04-20-2005 06:09 PM
3.07 Gearing MCanavan TJ Wrangler Technical Forum 2 04-04-2005 03:38 PM
Gearing in differential and gearing in t-case, little help ... farinspace TJ Wrangler Technical Forum 6 03-06-2005 02:31 PM
