| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
re gear a d44 with limited slip - is the shop right?
I got my D44 - now i need to regear - Anyone got a good place to go 'round charlotte? Building up to 35s |
#2 | |
Desert Runner
Any other you will need a new carrier.. Hope this helps
___________________________________________ In or Near San Diego, CA? Click Here Black Jeep Club Member #1016 NASCAR FAN Senior Member: Jeep Repair Club, San Diego Chapter
#3 | |
#4 |
I'm not sure thats quite correct. There is a carrier break at 3.92 so to run gears above 3.92 say 4.56 you will need a new carrier. Also if its a Rubi Axle you will need the "Thick" gearsets.
#5 |
it is a regular TJ D44 w/ limited slip.
#6 |
I believe you can use the Rubi thick gears but you have to do some drilling.
Jim
03 Sport |
#7 |
you need a different carrier. ran into the same problem when i regeared.
#8 |
For Dana 44's, the normal carrier break is 3.73 down and 3.92 up.
Rubicons had 4.1 gears on a 3.73 down carrier and were thckker than normal 44's. You can use these gears on your 3.73 down LSD carrier and they will be fine. It is done very frequently. You may have to drill your carrier for 7/16" bolt holes (instead of the normal 3/8") but it will be fine. This is a very common swap. You can easily find more confirming info if you surf a bit.
Jeepin's not a hobby, it's a lifestyle!! |
#9 |
JEEP FREAK
![]() Join Date: Apr 2004
You have 2 options when regearing a D44 from 3.73 to anything lower (4.10, 4.56, 4.88, etc.):
1. New carrier/locker and use standard gears 2. Thick cut gears used with your existing limited slip Thick cut gears are a way to use lower ratio gear ratios with the higher ratio carriers. They are not available for all axles, but they are available for the D44.
98 TJ 02 WJ |
#10 |
i wouldnt recomend tarheel 4wd they ordered the wrong lsd for my d44, they made me wait in the showroom for awhile to before they helped me, just my experience with them them. had a local guy here in mooresville put in a new r & p, and auburn lsd, for pretty reasonable but 450 sounds good for front and rear
#11 |
Excuse my chiming in but I have a D44 with 3.73's, while I have no immediate plans to regear this very moment I am attempting to understand the situation I share with the OP.
If I wanted to keep my carrier and were to order a ring and pinion from say, Quadratec. Would I order the gears for a D44 non rubicon or would I opt for the Rubicon listed parts. I have always wondered why they list two different D44 models but I think the thickness in the gears make sense for this scheme. Carriers are not cheap, yikes!
/l ,[____], l---L -OlllllllO- ()_)-()_)-o-)_) Live everyday like its your last, and learn every moment as if you will live forever. Last edited by JDePietro; 10-30-2009 at 06:38 PM. Reason: Price check! |
#12 |
i called randys ring and pinion and i ordered everthing for a non rubi d44, new ring gear, pinion gear, and auburn lsd (came in new carrier for around $275)
#13 |
i always thought you could just go with the thicker gears for the rubi in the d44 carrier with 3.73 and down that have the lsd
#14 |
If this is for off road use use should change your order to a Truetrac. The Auburn unit will burn up if you lift a tire. It is a clutch style LSD that will not hold up to off road use.
#15 | |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Dana 44 rubicon rear limited slip gear oil, synthetic or regular gear oil what weight | rutacon05 | TJ Technical Forum | 6 | 09-16-2009 08:53 AM |
| Limited Slip Mate Gear? | dr_finklestein | TJ Technical Forum | 0 | 04-27-2008 09:03 AM |
| Question about Gear Oil in a Limited Slip Diff | Chris @ GATR | TJ Technical Forum | 8 | 09-28-2007 10:30 PM |
| Anti-Slip / Limited Slip HELP!!! | mtb1981 | JK Technical Forum | 3 | 05-18-2007 07:06 AM |
| Val 75w-140 limited slip Full Synv gear oil | bikerjeep | TJ Technical Forum | 8 | 08-25-2005 01:49 PM |
The time now is 04:14 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
