Re-Alignment after 2" Teraflex BB Results - JeepForum.com
post #1 of 1 Old 10-05-2004, 06:08 PM Thread Starter
mkuzmukerau
mkuzmukerau's Avatar
Well, after putting on 32x11.50 BFG MT's, and a 2" Teraflex Budget Boost, I had my front end realigned at Firestone Car Care.... Here is my experience..
Well, to start, Toe-In is the only thing on the newer TJ's that can be adjusted, so its more of a toe-in then a front end realignment. The plan is $119, and is a lifetime adjustment plan that can be used as often as you want, and is not dependant on accesories, etc...
Here's the Beforehand....
Camber L-.52deg/R-.79deg
Cross Camber .28deg
Caster L5.19deg/R5.53deg
Cross Caster -.34deg
Toe L.61deg/R.47deg
Total Toe 1.08deg
And afterwards
Camber L-.43deg/R-.81deg
Cross Camber .39deg
Caster L5.19deg/5.53deg
Toe L-.24deg/R.52deg
Total Toe .28deg
Here are the supposed Jeep Specs/Tolerances
Camber -.25deg/.63 tol
Cross Camber 1.00deg tol
Caster 7.00deg/1.00deg tol
Cross Caster .65deg tol
Total Toe .30deg/.12 deg tol
So if anyone knows how to make any sense of it please chime in. But as of right now I am feeling like I probably should have listened to Jerry and did it myself... I still vear to the right a bit, and my wheel is still barely off center, probably from the vear....
Mike
2005 LJ Rubicon w/Savvy 4" and 35's
2009 XK Limited
2008 JK Unlimited Rubicon - Sold
2007 XK Rocky Mtn 4x4 - Totalled
2004 TJ X - Sold
mkuzmukerau is offline
Teraflex 2.5 Inch Lift Results crazymax JK Wrangler Technical Forum 14 05-25-2009 05:12 PM
Alignment results - should I be satisfied? wshngtn TJ Wrangler Technical Forum 9 03-21-2009 12:18 PM
3 " BDS lift install Results 6string TJ Wrangler Technical Forum 7 02-18-2009 03:07 PM
Alignment issues after Teraflex 2.5'' budget boost installation kam979 JK Wrangler Technical Forum 5 11-12-2008 04:30 PM
Nice results after RE 2.5" Lift. Cone YJ Wrangler Technical Forum 4 06-20-2007 01:31 PM
