RE adjustable rear track bar??? - JeepForum.com
post #1 of 6 Old 04-21-2007, 04:53 PM Thread Starter
NYwranglanator
NYwranglanator's Avatar
What end goes to the axle side and should I leave the old track bar bracket from my old lift or take it off???
Lou
99 TJ, D30/D44, I6, 5 Speed
RE 4.5" SF lift, JKS 1.25 BL & disco's, M.O.R.E. MML, Edge Trail Jammer, 33 x 10.50 BFG Mud's, PSC Rocker Knockers & Trail Cage, Aussie Locker up front,
NYwranglanator is offline
post #2 of 6 Old 04-21-2007, 05:05 PM
robncar
robncar's Avatar
The side with the rubber goes on the frame, the one with the heim misalignment setup goes to the axle. Did you get a bracket with the RE TB? There are two different ones, one for CV (angled #1602) and one for non-CV (straight #1603). Does it line up with your current bracket?
robncar is offline
post #3 of 6 Old 04-21-2007, 05:34 PM Thread Starter
NYwranglanator
I have the angled track bar. Looks just like the factory bar. I didn't get the bracket with my kit.
Lou
post #4 of 6 Old 04-21-2007, 06:01 PM
robncar
robncar's Avatar
Yes, the RE track bar is angled. Sorry I wasn't clear, I meant the RE TB brackets are either straight or angled. Hope it works out for you. When we did ours, we used the angled bracket because we had the adjustable upper control arms and a CV drive shaft.
robncar is offline
post #5 of 6 Old 04-21-2007, 06:14 PM Thread Starter
NYwranglanator
I have adjustable UCA and CV driveshaft(well I will before the weekend is out). I have a straight track bar bracket already on from my black diamond lift. The angled bracket will have to come later unless I run into problems. Right now everything looks like its going to work....I hope.
Lou
post #6 of 6 Old 04-21-2007, 06:32 PM
Vacant Stare
Once you rotate the rear axle to set the pinion angle, you may find that the trackbar doesn't clear the gas tank skid if you don't go to a bracket that angles it forward. You won't really know until you've adjusted the pinion angle, but it's a common scenario.
Vacant Stare is offline
Rear adjustable track bar after lift?? theplasterman TJ Wrangler Technical Forum 37 03-06-2010 11:18 PM
Rear adjustable track bar: RE vs. JKS armyRN TJ Wrangler Technical Forum 0 06-20-2009 01:44 PM
TJ adjustable rear track bar for BB captndiltz TJ Wrangler Technical Forum 5 04-25-2009 09:56 AM
Which adjustable rear track bar is right for me? whiteguyjames TJ Wrangler Technical Forum 7 02-17-2009 11:50 AM
rear adjustable track bar jayinMS TJ Wrangler Technical Forum 12 01-19-2007 01:31 PM
