RE Adjustable Front Track Bar and a 2" BB... ? - JeepForum.com
post #1 of 5 Old 12-31-2005, 09:49 PM Thread Starter
thejafe
thejafe's Avatar
Out of curiosity... can an RE Adjustable Front Track Bar (1600) be used with only a 2" BB? I know that with only 2" of lift it's not necessary BUT... will it fit, or must a stock track bar be used?
thejafe is offline
post #2 of 5 Old 01-01-2006, 08:42 AM
method84
method84's Avatar
Im pretty sure that trackbar is only good from 4-6" of lift because its designed for RE's 3.5,4.5 lifts. I think the same goes for the rest of adj, trackbars on the market. I think with a lift that small its more geared to just relocating the trackbar with a bracket rather than having and adj. trackbar
method84 is offline
post #3 of 5 Old 01-01-2006, 09:54 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
It soft of fits.
The length will adjust short enough.
The problem is that it will hit the front diff cover when the axle droops.
Wheelin98TJ is offline
post #4 of 5 Old 01-01-2006, 09:56 AM
Texas TJ
Texas TJ's Avatar
i believe JKS makes one for like 0-2.5" lift
2001 TJ YELLOW
I flopped and broke my piece
If it won't budge, get a bigger hammer, if it breaks in the process it needed to be fixed anyway.
Texas TJ is offline
post #5 of 5 Old 01-01-2006, 10:25 AM
jm76
Procomp also makes one for 0-3.5" lifts.
jm76 is offline
tj front adjustable track bars for 0-3.5", does yours hit or fit? mudb8 TJ Wrangler Technical Forum 1783 07-08-2016 11:34 AM
Front Adjustable Track Bar colder152000 TJ Wrangler Technical Forum 7 01-05-2010 06:32 PM
Adjustable Front Track Bar??? jrb470 TJ Wrangler Technical Forum 6 03-22-2009 04:02 PM
Do I really "need" an adjustable front track bar? Chris_ TJ Wrangler Technical Forum 3 06-26-2007 08:50 PM
Which adjustable front track bar should I get? kenskis TJ Wrangler Technical Forum 11 09-05-2006 06:44 AM
