#1 | |
RE 5.5LA complete...almost
I finished the Long arm kit this weekend. Total time to install 18hours..including down time. This was done by me and and another buddy who have never really done a full suspension kit. a few little issues..HOPEFULLY! I have a 8.8 in my TJ, and I have some questions. I bought the jeep used with the 8.8 already in it. I put all the control arms to length that RE recomends for the 5.5 LA kit. I have two issues right now. Worst of all it makes the jeep look terrible: mad:
1) the rake of the vehicle is huge. The rear is 3.25 inches higher then the front. Granted I dont have the rear bumper carrier on yet, or the spare....but 3.25" 2) the axle is not centered in the fenderwell. And I dont think I have many options. I have about 1" clearance from the driverside shock shaft and the gas tank, and the track bar is close to the gas tank. Update: The rear end has settled quite a bit since I added the weight in the back, and flexed out the suspension. The rear axle is centered perfect in the fenderwell. Now with the new Monotube shocks this thing rides great. I have to give Rubicon express's customer service a big thumbs up!
Sport TJ build everything below has a hyperlink to the install/review Rubicon Express Long Arm D30 Alloy axle shafts with Alloy U joints D30 Powertrax no slip locker Skid row skids engine- gas tank - radiator- steering box Expidition one trail series rear bumper and carrier Edge Trail jammer install/review Bestop Trailmax Aqua seat Bestop Super top Before you ask about a product in the Technical forums check out the product review section! Last edited by barry1me; 04-02-2007 at 01:08 PM.. |
#2 |
pirate squirrel
your tire carrier and spare will help alot to balance out the weight of your winch on the front . . . better to be high in back than low . . . could you improve the clearance of your rear shocks and track bar by adjusting the pinion angle ?
- Chuck - Nth Degree 4.5" short arm the "Dude" abides |
#3 |
180 lb Gorilla
Looks great! Feels good to get those ol' shorty's outta' there ...
Rake ... hmmm ... r u sure the springs in the front are the right ones? Your pic is on an incline, so it's hard to tell how bad it is flat ... Which axle's not centered? I'm tri-link in the rear, so not much help with measurements etc. but you can mostly eyeball the rear alignment by adjusting the track-bar and shorten/lengthen the arms half-turns at a time ...
Marc L - '05 WHITE Rubicon Unlimited DISCLAIMER: All of the statements made above are on the internet, so they MUST be true! Video: Moab '05 GoldenCrack MyStockRubi Video: Moab '07 GoldenCrack MyLiftedRubi |
#4 |
Some Call me RockDog
are you sure you got the 5.5 coils in the rear and not the 7.5s?
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#5 |
180 lb Gorilla
Here's a shot of the 5.5's next to the stock ones ...
#6 |
Yeah, this looks a little bit ridiculous. Sure it's only 3.25 inches? Looks like more.
![]() Front and back tires are equidistant from the bottom of the picture so this is dead level.
#7 |
Just kind of stabbing in the dark here, maybe someone else can offer some input that has a 8.8.
Perhaps the 8.8 is higher than the d35/d44 where the shock mounts are? The kit is intended for the stock axles, and maybe they offer different springs for 8.8 owners?
(O|||||||O)
l_l*-----*l_l Raskull - Metallic Silver '03 Jeep TJ Sport (pic) http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery Custom front bumper build Custom rockers build My build thread |
#8 |
I'm guessing that you got the wrong rear springs. Those look like the 7.5s.
'98 TJ, G2 33 spl. D44, HP D30,ARBs,4.10s, RE 4.5 LA,33in Mickey Thompson MTZs w/Pro Comp 15x10 alloys,Smittybilt XRC8 w/Amsteel rope, LED tail lites, Rampage top Link to my Hemi build thread http://www.jeepforum.com/forum/f9/so-begins-5-7-hemi-conversion-1277803/ FOR SALE: 4.0 motor & TF999 trans, Premier Power Welder 195 amp,Fabtech Rockers PM me for details....... |
#9 | |||
that was my first thought...checked part numbers and Im running the 6070 rears (5.5) and the 6040 fronts (5.5) Quote:
)Quote:
Sport TJ build everything below has a hyperlink to the install/review Rubicon Express Long Arm D30 Alloy axle shafts with Alloy U joints D30 Powertrax no slip locker Skid row skids engine- gas tank - radiator- steering box Expidition one trail series rear bumper and carrier Edge Trail jammer install/review Bestop Trailmax Aqua seat Bestop Super top Before you ask about a product in the Technical forums check out the product review section! |
#10 |
Glad to see you got the kit installed. I have a few comments about your "problems".
1) When we installed my buddies LA kit he had a little rake due to the front winch. I noticed you have a heavy front bumper and winch up front. That will cause it to sag in the front. The 8.8 does create about 1" lift in the rear because the axle tube is bigger in diameter than the D35 and D44. Plus you don't have any tire weight in the back. When you add the net affect of those things, it makes since that the Jeep would rake that much. Get 2" coil spring pucks for the front and put your spare tire on the back and see if that helps. Looks like you will be able to run 37" tires! 2) your track bar should be adjustable. Disconnect it on level ground and adjust it until your rear axle is centered. RE didn't take into account that you have that 8.8 in the rear, so there suggested track bar length is not going to be accurate. That reminds me, if you install the pucks up front, you will have to adjust the front track bar as well. I know how frustrating it is to have to tweak projects when you are near the end. I am cursed with that expectation. Good luck with the adjustments. |
#11 | |
Yeah im glad its done too. It was actually a pretty fun project. I would go to 37's but I honestly dont want to go that high right now. 35's are where I want to be. Gearing is good for it, and I dont want to start building up either axle right now I may have made a mistake and mispoken. When I meant the axle isnt centered in the fender wells, I meant that the whole axle assembly is closer to the front of the vehicle, not centered in the middle of the fender well opening.
#12 | |
#13 | |
#14 |
This space for rent.
It looks like you have the front springs in the back and the back springs in the front.
'97 SE Lockers and stuff |
#15 | |
no I have the right springs in the front and rear
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
