RE 4.5 super flex still good buy? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > RE 4.5 super flex still good buy?
Rough Country Lift Kits and Parts!Savings on Rancho Shocks, Struts and Lift KitsSavvy Aluminum Gas Tank Skid
Unread 01-08-2015, 11:08 PM   #1
D6jeeper
Junior Member
Looking at purchasing the RE 4.5 short arm kit this week. Still a good purchase? Anyone had issues?
I also spoke with a gentlemen at my local shop that had said I am paying more for the name than quality. What are your opinions?
D6jeeper is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 11:24 PM   #2
geroux
I have a 4.5 RE SA kit put on in 2006. Replaced springs and shocks since. Still have the CA's and adj TB's. I heard they have made improvements but if I were you I'd do some more research. Maybe enough research where a kit isn't the best way to go. There are better components i.e. CA's, springs, shocks, adj TB's etc you can piece together and probably be much better off.
geroux is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 11:59 PM   #3
J03_TJ
J03_TJ's Avatar
I'd buy something else if they have the hourglass shaped rubber bushings on one end. I have there old style with the superflex on one end and a rubber Clevite style on the other. Been happy with them. I did rebuild two of the superflex ends on the front lowers after about 50k miles because I severely neglected greasing them. The rear two I just took apart and cleaned up. They don't offer the Clevite style anymore, just the hourglass ones. I'm on their newest rubber compound in the rear uppers that have the hourglass style, have been replacing them every few years, I think I'm on my third set of bushings on just that one set of arms. Anyway, get something else, for sure any arms with. Johnny Joints or Metalcloaks. There is one fairly large company equivalent to RE stuff maybe rough country or something like that, haven't heard of bad reports of their latest designed spherical end joint, that's if you want to stay lower budget. Course if you want more proven/well reviewed stuff go with JJ or Metalcloak.
J03_TJ is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 12:00 AM   #4
afusco1222
Currie and Metalcloak are king of the TJ world. You won't find too many RE lovers due to their sub par control arm bushings.
afusco1222 is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 06:48 AM   #5
joe_jeep
Re springs are too high a rate for most jeeps except a fully armored lj.
Re twin tube shock are not good. Mono tubes aint bad though.
Re arms eat bushings.
Look at the currie 4" lift, mabey metalcloak too.
They are top notch.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 07:26 AM   #6
UTWeezul
I have RE Superflex arms. The arms have held up to some abuse and the superflex joints are fine. It does go through the rubber bushings though. I'd love to swap all of mine to Currie or Metalcloak arms.
35" MTR Kevlars
TNT Phantom Fenders
PSC full corners w/ 3" flares
HP30 and 8.8 w/ lockers
UTWeezul is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 10:44 AM   #7
armyRN
armyRN's Avatar
I've got the RE 4.5" superflex kit (but with the 3.5" springs); purchased it in 2008 for my 98 TJ. Plenty tall for 33" tires. I thought the RE shocks were too stiff; I'm half-way through replacing them with Bilstein 5100 series shocks. And I have replaced the rubber bushings a time or two. And the rear upper control arms I had replaced under warranty as the metal ring holding the rubber bushing went oval on me. But overall I've been pleased with it. I think of it as a good mid-range priced lift kit. If you go through 4x4groupbuy they sell package deals that include a SYE and a Tom Wood's CV rear driveshaft. When I was looking for a lift kit way back when, I compared piecing a kit together vs. a package deal, and the package deal worked out better. You still need to get a rear track bar and bracket.
You can teach manners, but you can't teach class.
Trailer build: http://www.jeepforum.com/forum/f27/m...hread-1180456/
armyRN is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 11:06 AM   #8
LJ Dave
I started with an RE 4.5 inch superflex short arm kit and wouldn't recommend it. Definitely check out MetalCloak and Currie/Savvy lift kits. They may be a little more expensive to start with, but you'll spend less time and money replacing stuff in the long run.
2005 Rubicon LJ 4.5 inches of lift, 35's
LJ Dave is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 12:00 PM   #9
Hosejockey61
+1
Buy once, cry once.
Hosejockey61 is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 12:42 PM   #10
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Another guy here with RE arms looking to get new ones.
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 04:23 PM   #11
D6jeeper
Junior Member
Thanks for all the help gents!
Looks like I am leading towards metalcloak 3.5 and add the sixpak later on. Anyone know about the sixpak shock performance?
Unread 01-09-2015, 05:30 PM   #12
joe_jeep
I hear alot of good stuff about the metal cloak lift!
I have not heard much about the shocks yet.
Nothing bad either, Just I dont think alot of people run them?
In theory they should have plenty of travel?
Im not bashIng them, just dont hear alot about them.
glfwda #6624
Unread 01-09-2015, 08:33 PM   #13
biffgnar
biffgnar's Avatar
IMO six packs are a gimmick. Equal or better options for cheaper.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 09:51 PM   #14
D6jeeper
Junior Member
Ideas? Bilstiens?
Unread 01-09-2015, 10:09 PM   #15
biffgnar
biffgnar's Avatar
Ideas? Bilstiens?
Bilsteins are popular here. Not my thing. Really depends on the budget. I'd look at Rancho 9000s or Foxes. I guess if you are talking six packs budget is decent size, but you can get Fox remote reservoirs and have them tuned by Alltech for materially less than six packs for example. Would do that every day of the week and twice on Sunday.
