RE 4.5 SF plans - JeepForum.com
post #1 of 7 Old 10-06-2010, 09:44 AM Thread Starter
jmohlerfaria
Re 4.5 sf help!!!
I'm planning on on lifting my jeep this winter. Iv added things on to my cars in the past but iv never lifted a vehicle or done anything major. I have just basic tools but i am pretty tech savy and want to start doing my own work. i was wondering if anybody has installed this lift alone or if i should attempt it instead of having someone else install it.
jmohlerfaria is offline
post #2 of 7 Old 10-06-2010, 09:54 AM
BYuen
BYuen's Avatar
I've installed this lift kit. It's all bolt on stuff and pretty straightforward. It will take some time though, especially if it's your first time working with suspension. It also depends on the tools you have. There are some good write-ups online. I would install the suspension yourself. Great way to get more familiar with your Jeep and save some cash!
Rubicon Express 3.5" Super Flex Suspension Lift Installation - Jeep TJ
BYuen is offline
post #3 of 7 Old 10-06-2010, 10:23 AM Thread Starter
jmohlerfaria
are there any specialty things i need to know such as steering or brake bleeding or tools
post #4 of 7 Old 10-06-2010, 10:27 AM
mdm
Farm Wheeler
The link BYuen gave you covers it well.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #5 of 7 Old 10-06-2010, 11:26 AM Thread Starter
jmohlerfaria
thanks for your help and the link installing the lift myself will save me some major $$$.
post #6 of 7 Old 10-06-2010, 01:28 PM
BYuen
BYuen's Avatar
This fellow JF member's writeup will help you a lot to set up your pinion angles. He basically did an axle swap and suspension at the same time.
high pinion dana 30 swap - very long with pictures - JeepForum.com
BYuen is offline
post #7 of 7 Old 10-06-2010, 01:39 PM Thread Starter
jmohlerfaria
yeah the axle swap looks like a big job but the lift is exactly the same to this should be a good reference. thanks for he link now i just need to fine the right drive shaft and shocks and i should be ready to oder my stuff
install , re 4.5" , rubicon express , suspension
plans for after CreepyCrawler95 YJ Wrangler Technical Forum 0 12-12-2009 09:05 PM
Plans for my TJ, could use some help ToyHunt3r TJ Wrangler Technical Forum 5 06-05-2009 09:35 PM
i said i had plans...here they go.. nickYJ YJ Wrangler Technical Forum 6 06-13-2006 02:36 PM
sometimes the best plans,,,, LTB YJ Wrangler Technical Forum 2 10-24-2005 12:50 AM
plans for a YJ birdkage YJ Wrangler Technical Forum 21 10-07-2004 12:02 AM
