RE 3.5 Standard Lift Upgrade to the Super Flex - JeepForum.com
post #1 of 4 Old 05-10-2009, 11:35 PM Thread Starter
Disco69
Has anyone upgraded their RE 3.5" standard lift to the 3.5" super flex? If I look at it correctly, the only thing that is different is the super flex comes with RE Discos and fixed F/R lower control arms. Right?
Anyone done this upgrade? If so, was their a difference noted on and off road?
2001 TJ Sahara
3.5" RE Superflex Suspension Lift -|- RE Adjustable Trackbar -|- 35x12.50 STTs on Eagle Alloy 15x10s-|- D30 w/ ARB and Superior Outer Axle Seals -|- D44 w/ Detroit Locker -|- Superior 4.88s -|- ROKMEN Mercenary Front Bumper -|- ROKMEN Sliders -|- Warn Rockcrawler Rear w/ Carrier -|- Warn M8000 Winch -|- JKS 1.25" BL -|- JKS 1" MML -|- Old Man Emu Long Travel Shocks -|- OME Stabilizer -|- ARB OBA -|- MetalCloak Arched Front Tube Fenders
Sienna Jeep Club Member #29
Disco69 is offline
post #2 of 4 Old 05-11-2009, 08:43 AM
otisdog
2008 WK
You don't have to use RE parts to upgrade.
The main reason for upgrading the arms is that they have a flex joint to help with articulation and they are a tad longer than stock to help regain the bit of wheelbase you lost when lifting. The disco's are a great improvement for offroad.
For instance you could get JKS discos and Currie or Rokmen control arms - there's no reason you can't mix and match.
I have Pro Comp 4" springs, JKS dicos and JKS upper control arms. I have RE Superflex lower adjustable control arms and a Terflex adjustable trackbar.
Any control arms you get make sure they have a flex joint and are not just solid arms with bushings.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #3 of 4 Old 05-12-2009, 01:43 AM Thread Starter
Disco69
Bumpity?
Bueller? Bueller?
2001 TJ Sahara
Disco69 is offline
post #4 of 4 Old 05-12-2009, 06:40 PM Thread Starter
Disco69
I guess my biggest question is that I'm wondering if the new control arms are "plug-n-play".
2001 TJ Sahara
Disco69 is offline
rubicon express 3.5 standard lift vs. super flex jeepy01 TJ Wrangler Technical Forum 5 05-03-2009 06:54 PM
Rubicon super flex vs standard lift? BChamberlin TJ Wrangler Technical Forum 12 03-10-2006 07:46 PM
RE Super flex or Standard flex treypal TJ Wrangler Technical Forum 10 06-21-2005 09:01 PM
Difference between RE Super-Flex and Standard 3.5" lift? rhinoss TJ Wrangler Technical Forum 4 03-17-2005 09:06 AM
RE 3.5 Standard or Super flex? nwacarguy TJ Wrangler Technical Forum 4 05-02-2004 12:17 AM
