Quantcast RE 3.5 lift question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > RE 3.5 lift question
Old 05-22-2007, 10:56 PM   #1
DBLJ
DBLJ's Avatar
I just bought a 97 TJ Sahara edition. I've been looking at lift kits and wanted to go with either a 3.5" or 4" lift. I'm trying to keep the price low but i understand i get what i pay for. I found the RE 3.5" and liked the price on it. I was wondering if i need anything extra that doesn't come in the kit. I'm not buying the kit until next month because i'm a poor college student and i dont want to sit on it and wait for more parts or find out that i need something midway through. . Any suggestions would be helpful. I'm open to new ideas.
5 speed I-6
61,000 miles
never been off-road until i got it.
DBLJ is offline   Reply With Quote
Old 05-22-2007, 11:06 PM   #2
JeremyJeep
I've been researching that kit as well and I think something important is a slip yoke eliminator kit for the nv231.
JeremyJeep is offline   Reply With Quote
Old 05-22-2007, 11:14 PM   #3
GringoLoco
Yep, pretty much all you'll need with the RE 3.5 lift is a SYE kit and CV rear driveshaft. If you go the high quality route, an Advanced Adapters SYE and Tom Woods driveshaft will run you $535 shipped. You can get a lesser driveshaft and save a few bucks though.
Oh wait.... does that lift come with shocks? Cause you'll need those too.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline   Reply With Quote
Old 05-22-2007, 11:16 PM   #4
DBLJ
DBLJ's Avatar
Yeah it comes with a choice.
TJ/LJ 2"-3.5" RE MONOTUBE KIT
TJ/LJ 3.5"-4.5" BILSTEIN SHOCK
TJ/LJ 3.5"-5.5" DT3000 SHOCK
TJ/LJ 3.5"-4.5" RUBICON TWIN
TJ/LJ 3.5"-5.5" OME SHOCK KIT
And this is the kit:
RE1145 ~ SWAY BAR END LINK, FRONT
RE1155 ~ SWAY BAR END LINKS REAR TJ
RE1172 ~ DISCONNECT ADAPTERS TJ/ZJ 96+
RE1363 ~ COIL SPRINGS TJ 3.5" FRONT/PA
RE1365 ~ COIL SPRINGS TJ 3.5" REAR/PAI
RE1380 ~ BUMPSTOPS 2" FRONT LOWER
RE1385 ~ BUMPSTOPS 2" TJ REAR UPPER
RE1603 ~ TRACK BAR BRACKET TJ REAR W/O
RE2100 ~ T-CASE LOWERING KIT YJ/TJ 1"
Old 05-22-2007, 11:17 PM   #5
27jeep27
Good lift
I have the RE 7002 3.5 lift and am very satisfied. It does ride very tall and you may or may not need a SYE and new driveshaft (500$). I had to use the transfer case drop and 3 washers to get rid of driveline vibes. I used Skyjacker Hydro's (4 for 130$) and the ride is nice, but I am sure it could be better. Many people prefer the OME 2.5 kit from DPGoffroad. If I had it all to do again, based on my use, I would do the OME kit with with a 1" body lift. Just my opinion.
27jeep27 is offline   Reply With Quote
Old 05-22-2007, 11:42 PM   #6
DBLJ
DBLJ's Avatar
Do i need the SYE and CV driveshaft right away? Im not looking to spend a lot but I am looking to do this right. How will i tell if i need the SYE and CV driveshaft?
Old 05-22-2007, 11:55 PM   #7
87warrior
With much luck, on the SWB TJ you will not get driveline vibes. It may be possible to dial out the vibes with Adjustable lower/upper control arms. I tried this on mine. 99% of my vibes were dialed out, but there was drive shaft grinding... which disapeared after the CV install.
Being a broke college student as well, I would take an alternate route if I had to do it over agian:
-Full traction/BDS/Rusty's 3" lift springs (USED - check forum for sale section)
-OME Shocks (new)
-Front extended brake lines (the stock back is plenty!)
-JKS disconnects - (USED or NEW)
-RE Extended rear swaybar links (new/used)
-1" Body lift (new)
See if it needs the SYE/ CV. If it does, look into the Hack-n-Tap SYE. I have never done it, but understand it is tough and works great if done right if on a budget. If yes, add Nth Degree adjustable upper control arms to the list to dial in the pinion angle. Might also concider a belly up skid plate before ordering the CV shaft!
Then upgrade the control arms/steering/axles/armor as budget allows.
03 Rubicon(Rubicon build)
92 Comanche (92/99 Comanche Project)
87warrior is offline   Reply With Quote
Old 05-23-2007, 08:25 AM   #8
luk4mud
You are going to need extended front brakelines and very likely an adjustable front track bar. You already know about the SYE/CV issue.
All considered, because the RE3.5 nets more than 3.5" which will likely lead to a SYE/CV, I would either spend the big bucks on the re4.5 SF kit (which gets you control arms) and swap in 3.5 springs, or go the 3" BDS/ Full Traction (or something similar ) route. Just my
Originally Posted by Divinitous
I did something like this a while back for my corolla. I poked a hole into the ducting and ran a hose to stick into my shorts. It didnt work thew best cause I never plugged up the vents, but it did help.
luk4mud is offline   Reply With Quote
Old 05-23-2007, 12:44 PM   #9
DBLJ
DBLJ's Avatar
-OME Shocks (new)
-1" Body lift (new)
that sounds like the way to go. With the 1" BL what do i need to do?
Old 05-23-2007, 12:52 PM   #10
Jon_H
With a 1" BL, you basically just need the BL. But you'll probably also need a motor mount lift, which isn't much if I remember right.
Jon H.
'97 TJ Sahara | 31" BFG A/Ts | Dynomax exhaust system
Stock Jeep Club Member #36
Silence is golden, but tape is silver.
Jon_H is offline   Reply With Quote
Old 05-23-2007, 01:00 PM   #11
rivers edge
My dad's jeep has that kit(3.5 R.E. short arm kit), with a 1" body spacer and it looks great! He doesnt have the sye kit on it and it does fine for driving down the high way! So unless you have the extra money, I wouldnt worry too much about doing the sye immediately! Here is some pics:
www.riversedge4x4.com
'78 CJ- 5 (O'l Green), '99 TJ on rocks (li'l man), '07 JK (rattle can)
rivers edge is offline   Reply With Quote
Old 05-23-2007, 01:41 PM   #12
DBLJ
DBLJ's Avatar
How big are his tires?
I'm also looking at the full traction 3" econ or the rusty's 3" basic with extras.
I'm leaning towards Rusty's with the 1" bl, 1' raised MM, steering upgrade, and their performance shocks all for a grand total of $589.
Glock Forum
