RE 3.5" Install help ! How to drill a hole in the rear track bar bracket ? - JeepForum.com
post #1 of 2 Old 09-29-2004, 10:52 AM Thread Starter
Humberto Benavides
Humberto Benavides's Avatar
I'm just waiting for my 3.5" RE Super Flex to arrive and I have been reading the install instructions from www.rubiconexpress.com, they mention to drill 2 holes in the rear trackbar bracket and original trackbar mount, one in the top and one in the angled side of the original trackbar mounting location, I just taked a look at my jeep and don't figure out how to drill the one in the top, space is tight there !!!
I think that everyone that has installed this suspension kit was in the same situation, how do you resolved that ? Any advice or tip ? Thanks !
'03 Jeep Wrangler X Auto I6 4.0L, 3.5" RE Super Flex, 1" PA BL, M.O.R.E. 1" MML, 33x12.5x15 MT/R's, JKS Quick Discos, RE Front Adjustable Trackbar, Skyjacker Hydro7000 Shocks, OEM RUBICON Rocker Guards, WARN Steering Skidplate, Front Mopar Tow Hooks, Bushwacker 6" Extended Fender Flares, K&N drop-in air filter, Chicago Electric Winch, SS light bar with 4 Hella 500 Driving Lights, and stock no more !
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
Humberto Benavides is offline
post #2 of 2 Old 09-29-2004, 10:58 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Support the frame by jackstands, unbolt the shocks from the axle and then unbolt the lower anti-swaybar links. Then lower the axle down with via the floor jack it was supported with and you will have much better (but stilll not great) access. I've drilled that bracket and while it's not easy, it can be done after unbolting the shocks and swaybar links to give the axle as much droop as possible.
Jerry Bransford is online now
Front trackbar relocation by drill and rear trackbar relocation bracket install? loudog3114 TJ Wrangler Technical Forum 20 10-26-2014 08:01 PM
problems with rear track bar bracket install wingshooter2009 TJ Wrangler Technical Forum 3 06-06-2009 07:49 AM
Rear Track Bar Bracket? Is it needed on RC 2.5" Lift? dirttrackfans TJ Wrangler Technical Forum 6 04-25-2009 06:02 PM
OME Track Bar Bracket Install MCanavan TJ Wrangler Technical Forum 15 03-28-2006 11:46 PM
2" Coil lift question....Rear Track bar bracket. 97grntjsahara TJ Wrangler Technical Forum 4 05-05-2004 11:35 PM
