RE 3.5 with 35's - JeepForum.com
post #1 of 26 Old 06-25-2005, 03:45 PM Thread Starter
jeep jake
RE 3.5 with 35's
Has anyone ran this setup, and if so can you post a pic, and How do you like it.
jeep jake is offline
post #2 of 26 Old 06-25-2005, 04:13 PM
makara
I just put on 35x14.50 boggers on my jeep. Right now I have the 3.5 inch RE lift which I used when I had 33x12.50 swampers. I figured that once the 35s went on that I wouldn't be able to drive until I put on a bigger lift but I have been very suprised at how well the 3 inch is working with the larger tires. The tires are brand new so I haven't had a chance to try it out off road yet. I'm sure that I will get rubbing with much articulation so I thnk that I am going to go to a 4.5" long arm very soon. For street driving though, it works great with the exception of tires rubbing with extreme steering input.
makara is offline
post #3 of 26 Old 06-25-2005, 04:43 PM
James04TJ
James04TJ's Avatar
I have the RE 3.5" kit with a JKS 1.25" body lift and I think that setup is perfect for 33's. It would be fine for street driving but I just dont think that it would cut it for the trail. My plan is to go with the JKS ACOS when I add 35's.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #4 of 26 Old 06-25-2005, 04:50 PM
supaasianpdjr
I will be putting on a "4 skyjacker lift tomorrow and will be running "35s. eventually maybe need to put on a "1 BL but I am holding off on that now. I will post pics tomorrow night when I get done with it.
supaasianpdjr is offline
post #5 of 26 Old 06-25-2005, 06:42 PM
dirtgrip
dirtgrip's Avatar
An RE 3.5with a body lift of 1- 1.25 should work fine with 35,s.Many here have done it as an RE 3.5 actually lifts closer to 4.5 in.I run a 4in lift with a 1in body lift & have only touched the front flare once.This can be fixed with a little bumpstop adjustment but as front D60 is due in I,ll wait.
Large vacuum leak sucking all the dead presidents out of my wallet.
dirtgrip is offline
post #6 of 26 Old 06-25-2005, 06:58 PM
old soldier
On my 2003 Rubicon I have the 3 1/2" RE Super Flex kit with a one inch body lift and run 35 X 12.50 Super Swamper SSR's. I have no problem.
Jim
Locked and Loaded, Nuff said. Anything else is an ego trip.
old soldier is offline
post #7 of 26 Old 06-25-2005, 08:15 PM
jeepman14wheel
jeepman14wheel's Avatar
I rub hard with the RE3.5 and 33" tires, not usre what is up. I even comp cut the rear and tube fendered the front and I still rub! I hit some very hard trails though!
RE 3.5 lift, 1" BD/MT lift, 33.12.50 MTRs, Teralow, SYE, Detroit locker, Eaton E locker, Dana 44 front, Ford 8.8 rear, warn winch, full roll cage, Fuel cell.
jeepman14wheel is offline
post #8 of 26 Old 06-25-2005, 09:49 PM
makara
35x14.50 boggers with a RE 3.5 inch lift
Yeah, it's a poser shot but I haven't had a chance to take it off road in the four days they have been on.
makara is offline
post #9 of 26 Old 06-25-2005, 11:27 PM
biffstephens
biffstephens's Avatar
I have 35's, 3.5 lift and a 1 in BL.....
Steering rubs a little in one direction but that is it....
Biff
Wheel Spacers? Aluminum Fairleads? Winch Rope? LEDS? Winches? Accessories.....
Biff
biffstephens is offline
post #10 of 26 Old 06-26-2005, 12:24 AM
udamann
udamann's Avatar
Here's mine with RE 3.5 and a 1.25" bl and 35x12.50
94 ZJ Limted 4" Lift & 31s
98 TJ, 37" IROKS on 17" Allied Bealocks, Dana 44s front and rear
00 WJ Limited, 4.7L V8, 2" Lift with rubi take offs
"If we weren't all crazy we would all go insane" ~J. Buffett
udamann is offline
post #11 of 26 Old 06-26-2005, 03:35 AM Thread Starter
jeep jake
hey thanks for the pics and the reply's, how is it as a daily driver and do you recomend 4.88 gears
post #12 of 26 Old 06-26-2005, 12:06 PM
makara
Like I said, I just got mine and wanted to see how it drove before I made any decisions about suspension or gears. I have the 3.73s right now and they are not as bad as I thought they would be FOR THE ROAD. Offroad, I think I might go a little nuts with them. I think that I will be ordering 4.88s very soon.
makara is offline
post #13 of 26 Old 06-28-2005, 11:24 AM
supaasianpdjr
Here's the pic of my "4 with 35s.
I have 3:55 gears and its not that bad. Eventually I will regear and get a 44.
post #14 of 26 Old 06-28-2005, 12:17 PM
ATL TJ
I have the RE 4.5" SF w/ 1" body and my 35" tires rub when flexing. But then again I have the Sahara flares and 15x10 wheels.
ATL TJ is offline
post #15 of 26 Old 06-28-2005, 01:39 PM
Spartan302
Spartan302's Avatar
With bump stops set correctly you can run 35's with the 3.5" and a 1"bl. With 35's I would run 4.88's.
Spartan302 is offline
35's on the D35..!? Dave0392 YJ Wrangler Technical Forum 31 01-25-2011 02:36 AM
35's on a 3.5''??? gamble3527 TJ Wrangler Technical Forum 11 09-29-2009 10:16 AM
Let's see JK on 35's JayDLT JK Wrangler Technical Forum 59 02-28-2007 01:33 PM
4.5 w/35's Rubicon153 TJ Wrangler Technical Forum 28 02-19-2007 12:09 AM
35's and a d30 stevegittings TJ Wrangler Technical Forum 7 10-27-2005 03:09 PM
