Quantcast RE 1602 Rear CV Bracket instead of OME bracket.... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > RE 1602 Rear CV Bracket instead of OME bracket....
Old 09-21-2006, 04:34 PM   #1
thejafe
I'm looking to install this bracket on my TJ but I currently have an Old Man Emu rear track bar bracket installed. Has anyone run into complications when trying to swap in the RE 1602 for the OME (holes not linining up etc?) Thinking about bumping up to the RE 3.5" Superflex with adjustable upper control arms. Just gotta iron out the details before I pull the trigger....
Visit My Homepage!
thejafe is offline   Reply With Quote
Old 09-21-2006, 04:45 PM   #2
ISurvivedNMU
The RE read track bar uses all the same factory holes and hardware.. So it should bolt right in, ulnless the OME had you drill?
2006 Jeep TJ Rubicon... Currie 4" Lift, Currie Steering & Anti-Rock, Warn 9.5, Full Skids, Rock Hard 4x4 Sport Cage, LOD Rear Bumper & Tire Carrier, ect...
2011 Grand Cherokee Overland
Into John Deere Tractors? www.deeretalk.com
ISurvivedNMU is offline   Reply With Quote
Old 09-21-2006, 05:18 PM   #3
thejafe
Yep, the OME has you enlarge 2 of the existing holes... .
bump.........
Visit My Homepage!
Glock Forum
