Rcv shaft install - Page 2 - JeepForum.com
post #16 of 16 Old 08-12-2010, 12:41 AM
jdhallissey
Originally Posted by Aevrubi06 View Post
Its a D44. The R&P is under full warranty and if it breaks then it just gives me something to fix, thats what wheeling is about. I wheel with 36" swampers and i run 37"km2's on the road which is maybe once a month when i drive it. Warn hubs won't guarantee breakage before the R&P, I run rubi air lockers and harldey ever need to use them so that is highly unlikely to break the teeth of the ring gear with an open diff. But theres always a first for everything!
What you missed in this is explaining this more---
Stock rubi lockers will explode before you break the R&P. So if you happen to be wheeling it and you break a locker it then goes open and you still get home. Problem solved.
jdhallissey is offline
rcv , axle shaft
RCV Axle Shaft install in D30... Mino TJ Wrangler Technical Forum 8 09-22-2010 12:11 AM
Chromo shaft install questions Toms87 YJ Wrangler Technical Forum 5 05-16-2010 07:07 PM
sye/tt/shaft install chutta TJ Wrangler Technical Forum 5 05-04-2007 10:25 AM
SYE and CV Drive Shaft Install costs cyclerider105 TJ Wrangler Technical Forum 20 11-02-2006 02:05 PM
Drive Shaft Install billy mo TJ Wrangler Technical Forum 11 06-23-2006 07:14 AM
