RC X-flex vs Currie adjustable control arms - Page 5 - JeepForum.com
post #61 of 65 Old 09-22-2012, 02:26 AM
SlackJaw
baby jeep
SlackJaw's Avatar
Originally Posted by mrblaine
You are entirely correct of course. If you try and deny it long enough, and loud enough, perhaps we'll not remember glaring examples to the contrary.
As usual, you are ignorant to the details of my personal being.
Unsubscribed...place a HUGE bet on this one.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #62 of 65 Old 09-22-2012, 07:15 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I don't need to be privy to the details of your personal life to notice distinct changes in your posting demeanor as the evening wears on. Couple that with your previous admissions and it matters not the cause, only the results which we all get to enjoy.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #63 of 65 Old 09-24-2012, 01:30 PM
TroubleNEO
I stand corrected, upon further inspection this weekend I did not wear out the upper joints on my front radius arms. Instead I completely blew the joints apart, spitting that threaded washer you screw down with the spanner wrench completely out of the joint and flattening the threads on both the joint housing and the washer.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #64 of 65 Old 09-25-2012, 11:36 AM
Imped
Imped's Avatar
Well if that's not a good piece of evidence, I don't know what is.
OlllllllO
IndyORV
Imped is offline
post #65 of 65 Old 09-25-2012, 01:37 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I'm not sure that tells us much other than you shouldn't run that style joint in a radius arm for the upper. A radius arm front depends on the rotation of the main arm around the long axis to let the axle articulate. A normal bushing can deflect sideways when the arm binds the yoke on the sides of the mount and pries sideways on the bolt sleeve. A cartridge joint not so much.
I am Savvy
mrblaine is offline
rc , rough country , xflex , currie , adjustable control arm
currie adjustable arms too short or bad install? motobob TJ Wrangler Technical Forum 168 01-19-2016 09:35 PM
Currie Adjustable Control Arms Question alvinl TJ Wrangler Technical Forum 6 09-12-2009 07:33 PM
Rokmen vs Currie Adjustable Control Arms illinijeep TJ Wrangler Technical Forum 14 01-15-2009 07:33 PM
Currie or JKS control arms millhouse1 TJ Wrangler Technical Forum 3 10-13-2007 07:26 PM
Adjustable VS. Non adjustable Control Arms Daylan TJ Wrangler Technical Forum 3 12-04-2006 11:10 PM
