RC X-flex vs Currie adjustable control arms - Page 4 - JeepForum.com
post #46 of 65 Old 09-21-2012, 06:42 AM
tailhole
Originally Posted by Jeepson33s
Does anyone have pictures of these failed x-flex series joints? I have them and always hear how they fail but never see it.
I through mine in the trash. So I dont have a pix.
But the joint gets slack in it.
Sounds like a broke motor/trans mount.
A video would show it better then a pix
tailhole is offline
post #47 of 65 Old 09-21-2012, 09:08 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by biffgnar View Post
What ever happened to that jeep? Do you seriously have it? Definite classic.
I have it now. I'm trying to help the guy get it road worthy but after a more thorough inspection, I told him my absolute best advice would be to walk away.
It's a snowball of epic proportions in that if you touch one thing to fix it, you have several more that will need to be fixed.
Just to fix the brakes is downright right goofy with how much work it is.
The fab center console has to be removed to install a parking brake, which means the seats get replaced because the race seats attach to the sides of tube console which means a new t-case shifter goes in, which means the 3" body lift leaves which means the radiator gets raised, steering bearing gets raises, brake lines are above the frame and get dropped, cutting brakes get removed and an OEM center console goes in with factory seatbelts.
The AC estimate was 1800 dollars. Check engine light is on, it has no power and won't stay running for longer than about 15 minutes at a time before it starts cutting out, the very long long arm suspension clunks badly on brake events, the 38's need replacement now or sooner and it tries to go into DW at 30 mph.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #48 of 65 Old 09-21-2012, 10:30 AM
Kodiak17
Sounds like a good part-out.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #49 of 65 Old 09-21-2012, 10:39 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Frame is bent slightly, initial cost is too high to recover enough to balance out even somewhat favorably. Air bags are missing, aftermarket steering wheel is installed, dash is crap, carpet is missing, tub needs body work, fenders have been replaced with some ulta heavy tube crap.
Race seats are sun rotted, harnesses are shot, cage is crap and there are no bumpers. Battery is shot and won't hold a charge. The HP Dana 30 is likely geared to 3:5x to match the fantastic Dana 35 they slung under the rear. Factory belly skid is hacked up around the welded in place long arm mounts.
It does however have a new SYE with Tom Wood driveshaft and 2 ARB switches that aren't connected to anything because there is nothing for them to connect to.
I am Savvy
mrblaine is offline
post #50 of 65 Old 09-21-2012, 10:40 AM
biffgnar
biffgnar's Avatar
But the custom paint job is *****in!!
Romney in 2020!
biffgnar is offline
post #51 of 65 Old 09-21-2012, 10:48 AM
SlackJaw
baby jeep
SlackJaw's Avatar
Is this some kind of reverse sales technique? I mean isn't your normal m.o. to berate a guy into oblivion for his stupidity in not buying what you're selling
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #52 of 65 Old 09-21-2012, 10:52 AM
Imped
Imped's Avatar
Does it really need to be explained?
OlllllllO
IndyORV
Imped is offline
post #53 of 65 Old 09-21-2012, 10:52 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you believe that's my normal MO, then you're dumber than you normally act and that's saying a bunch.
I am Savvy
mrblaine is offline
post #54 of 65 Old 09-21-2012, 10:53 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Forget who you were talking to for a second there?
I am Savvy
mrblaine is offline
post #55 of 65 Old 09-21-2012, 10:54 AM
Kodiak17
My god... I would've slapped the seller in the face.
Kodiak17 is offline
post #56 of 65 Old 09-21-2012, 10:57 AM
SlackJaw
baby jeep
SlackJaw's Avatar
no
except I did get a bit thrown off why my reply garnered a response of a guy trying to sell me a ****wagon...
Perhaps he meant to post it to my profile page comments instead of here
SlackJaw is offline
post #57 of 65 Old 09-21-2012, 11:01 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It was a dealership back east in Illinois or similar. Guy bought it and had it shipped out only to find the pics posted were a bit misleading.
I am Savvy
mrblaine is offline
post #58 of 65 Old 09-21-2012, 11:51 AM
Robert J. yates
I'm guessing it's happy hour over in Okie land.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #59 of 65 Old 09-21-2012, 11:52 AM
SlackJaw
baby jeep
SlackJaw's Avatar
loud enough, long enough.
SlackJaw is offline
post #60 of 65 Old 09-21-2012, 09:32 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You are entirely correct of course. If you try and deny it long enough, and loud enough, perhaps we'll not remember glaring examples to the contrary.
I am Savvy
mrblaine is offline
rc , rough country , xflex , currie , adjustable control arm
currie adjustable arms too short or bad install? motobob TJ Wrangler Technical Forum 168 01-19-2016 10:35 PM
Currie Adjustable Control Arms Question alvinl TJ Wrangler Technical Forum 6 09-12-2009 08:33 PM
Rokmen vs Currie Adjustable Control Arms illinijeep TJ Wrangler Technical Forum 14 01-15-2009 08:33 PM
Currie or JKS control arms millhouse1 TJ Wrangler Technical Forum 3 10-13-2007 08:26 PM
Adjustable VS. Non adjustable Control Arms Daylan TJ Wrangler Technical Forum 3 12-05-2006 12:10 AM
