RC 3.25 lift and 33's - JeepForum.com
post #1 of 3 Old 07-20-2010, 07:20 PM Thread Starter
stockstuck
So here's the deal. I've been stock for too long and its time I get some height and some tires. I'm thinkin about getting the RC 3.25 lift for my 97 4.0L TJ. Also I would like to throw on some 33's on. I currently have Dana 30's with 3.07 gearing and wanted to know if I could run 33's on them. If not what should do. Also I'd like a safe set up, but I'd also not like to pay too much. Very small budget. I know its not as simple as chucking on a lift and some big tires. so someone fill me in on what I'm missing here, fill me in on any unforeseen costs and parts im gunna need. how much is the whole thing gunna cost?
stockstuck is offline
post #2 of 3 Old 07-20-2010, 07:42 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You most likely have a d35 rear.3.07's and 33's would be pretty sluggish without a regear.Some people do it though.You might want to get 33x10.50's.I had the RC 3.25" lift with a 1" BL and 35's with 3.73 gears.
TheBoogieman is offline
post #3 of 3 Old 07-21-2010, 12:53 PM
ncparsley
I have a 97 TJ with the 3.25 RC lift and 33's with 3.07 gears and i hate it. The lift is fine but I wish i would have gone with a smaller tire option in the first place so i could have saved for the regear before i did the tires. I tried doing some easy rock crawling with it but it just went too fast, even in 4low, to do anything with any technical skill at all. I just ended up bouncing and almost breaking a bunch of stuff when i flopped off the rocks. But to each there own. If you don't want to drive it much off road and you don't mind a slow *** jeep then it might be for you. Good luck with whatever you decide.
ncparsley is offline
rc , rough country , 33 , 3.25 , 3.07 , tj , wrangler , advice , help , suggestion
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 04:06 PM
Best Lift kit for a 4cy Tj on 33's tuckin18s TJ Wrangler Technical Forum 10 08-10-2009 10:17 PM
What kind of lift? 33's 4 inch lift. Adam567 TJ Wrangler Technical Forum 36 07-28-2009 06:41 PM
3.5 lift and 33's ufatbastehd YJ Wrangler Technical Forum 1 02-19-2006 06:31 AM
Trying to Decide: 31's no lift or 32, 33's with Lift? Pics wanted! mkuzmukerau TJ Wrangler Technical Forum 20 07-16-2004 12:35 PM
