RC 2.5 Lift - Page 3 - JeepForum.com
post #31 of 35 Old 08-02-2010, 01:13 PM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Originally Posted by cam36 View Post
Those are some badass jeeps! How do you like the RC 3 1/4 lift? Would you reccomend it over the 2.5? Its my dd and I'm only gunna do some mild wheeling everyonce in a while
Thanks.I'd go with the 2.5" lift and a 1" BL if more room is needed.With the 3.25" lift there's more chances of vibes.I went a little higher because I planned on running 35's from the start.Jeffery from RC (RCXTEME)gave me some good deals on everything I needed.
TheBoogieman is offline
post #32 of 35 Old 08-02-2010, 01:18 PM Thread Starter
cam36
Okay cool thanks! I plan on doing 33's max
2012 Jk Sport S 6 speed
4.56s Detroit Trutrac rear
37x12.50 Nitto Trail Grapplers
3inch BDS w/ bilstein 5100s
cam36 is offline
post #33 of 35 Old 09-30-2010, 04:10 PM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
I did the 3.25 but all it really is, is a 2.5 with a 3/4 spacer. if you put the spacer in front like i did you wont have to worry about vibes. Im running 35s with that setup.
2014 TJOTY Winner
IG: overlanding_racingdriver_
A Daily Driven Lowrider Adventure TJ on 40s.
NYGLT56 is offline
post #34 of 35 Old 09-30-2010, 04:23 PM
Cavitation
The real big difference with the 3.25 and the 2.5 is you get better sway links with the 3.25 kit. And of course 3/4 inches more lift.
My 3.25 kit only needed 1/2 inch of washers.
Cavitation is offline
post #35 of 35 Old 09-30-2010, 05:18 PM
apacheman75
I did the 3.25 and have ran it for a year with no issues. You also get the rear trackbar bracket with this kit! I had slight vibes but just dropped the TC and good as new.
apacheman75 is offline
rc , rough country , 2.5 , lift , suspension , tj , wrangler
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 04:06 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 09:11 AM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 08:04 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
