RC 2.5 Lift - Page 2 - JeepForum.com
post #16 of 35 Old 08-01-2010, 11:13 AM
bmw91
some tires come in 33x10.5
bmw91 is offline
post #17 of 35 Old 08-01-2010, 03:57 PM
scoin
I've had this lift on my jeep since April w/ a 1in spacer in the front running 33/10.50 bfg at. It's my dd and I haven't had any problems with it. The ride is nice, no vibes and with spacer it sits pretty level. Like they said every jeep is different, be prepared spring for more than just the lift.
scoin is offline
post #18 of 35 Old 08-01-2010, 04:18 PM Thread Starter
cam36
Hot rims man, where'd ya get them?
2012 Jk Sport S 6 speed
4.56s Detroit Trutrac rear
37x12.50 Nitto Trail Grapplers
3inch BDS w/ bilstein 5100s
cam36 is offline
post #19 of 35 Old 08-01-2010, 08:34 PM
scoin
Thanks, painted the stock ravines.
scoin is offline
post #20 of 35 Old 08-01-2010, 08:52 PM Thread Starter
cam36
What did ya do? Rough em up with some steel wool and then what kinda paint did ya use?
cam36 is offline
post #21 of 35 Old 08-01-2010, 10:36 PM
scoin
Prep is key, used a 3m pad to take the clear off, cleaned em real good, taped off the tires and sprayed 3 coats of rustoleum wheel paint. Had a wrx that I did the same using duplicolor wheel paint which I liked more. They say to use a clear coat but I didn't on either set. I get chips from rock here and there but after a year nothing major, if i see a few nicks i walk out w/ the rattle can and hit em real quick.
Dupli-Color :: Wheel Coating
RustOleum.com
scoin is offline
post #22 of 35 Old 08-01-2010, 10:50 PM
kadbow
I put the RC 2.5 on a couple weeks ago, it went on really nice and easy, no problems.
kadbow is offline
post #23 of 35 Old 08-02-2010, 09:33 AM Thread Starter
cam36
Hmm okay cool, I have the lame stock wheels so idk how it'll look but ill def look into it thanks man!...and kadbow- did you have to do a mml or a transfercase drop?...how's it ride compared to stock?
cam36 is offline
post #24 of 35 Old 08-02-2010, 10:23 AM
kadbow
I did the tc drop with the spacers that came with the kit. It rides nice and looks nice. I am not a hardcore 4WD guy but I get off the beaten path in my hunting excursions and wanted the added clearance without breaking the bank and a lot of mods. It is a better ride than the stock suspension IMO, doesn't beat you to death but is firm. Here is how mine looks with 31s. You could go 32s no problem with just the 2.5 lift.
kadbow is offline
post #25 of 35 Old 08-02-2010, 10:37 AM
TheBoogieman
Still disturbed
TheBoogieman's Avatar
I used the RC 3.25" lift with a BL/MML and 35's on lame stock wheels with RC wheel spacers. The t case drop spacers are way too much drop for the 2.5" lift.You could do a MML or drop the skid with just enough washers.
TheBoogieman is offline
post #26 of 35 Old 08-02-2010, 11:09 AM
kadbow
Boogie, the tc drop does seem like a lot with the provided spacers, how much drop is actually needed?
kadbow is offline
post #27 of 35 Old 08-02-2010, 11:42 AM Thread Starter
cam36
you only did a mml and tc drop? Did you have to do a sye?....both of you really nice jeeps btw
cam36 is offline
post #28 of 35 Old 08-02-2010, 12:40 PM
TheBoogieman
Still disturbed
All jeeps are different,but usually 1/2" or just an MML.
post #29 of 35 Old 08-02-2010, 12:45 PM
TheBoogieman
Still disturbed
I did an MML and 1/2" t case drop and no SYE.Green willys Jeep behind my white one is my brother's.I did the same MML and 1/2" t case drop.I installed his RC 4" lift with 3/4" spacers up front.
post #30 of 35 Old 08-02-2010, 02:07 PM Thread Starter
cam36
Those are some badass jeeps! How do you like the RC 3 1/4 lift? Would you reccomend it over the 2.5? Its my dd and I'm only gunna do some mild wheeling everyonce in a while
cam36 is offline
rc , rough country , 2.5 , lift , suspension , tj , wrangler
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 05:06 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 10:11 AM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 09:04 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 10:04 AM
