RC 2.5 Lift - JeepForum.com
post #1 of 35 Old 07-31-2010, 01:14 PM Thread Starter
cam36
RC 2.5 Lift
Okay im sure this question has been asked before, but here it goes, I have a stock 06 sport and im looking for a lift, i think im set on the RC 2.5 inch lift, and i wanna run 32s maybe 33's. If i get the 2.5 inch lift will i need to do a mml, sye, or anything other than the lift itself? This is my DD and im only looking to do some mild offroading every other month or so.
2012 Jk Sport S 6 speed
4.56s Detroit Trutrac rear
37x12.50 Nitto Trail Grapplers
3inch BDS w/ bilstein 5100s
cam36 is offline
post #2 of 35 Old 07-31-2010, 01:51 PM
SugarBear
1969 CJ5
No, you won't need to make any modifications. Just the 2.5" lift itself.
1969 CJ5
2.5" Rancho Kit/Shocks/Steering Stabilizer, 2" Shackles, Koenig PTO Winch, 31x10.5x15 Cooper STT's
SugarBear is offline
post #3 of 35 Old 07-31-2010, 02:13 PM Thread Starter
cam36
okay cool, and maybe i was thinking 1 inch spacers on top of that, will that be too much?
cam36 is offline
post #4 of 35 Old 07-31-2010, 03:02 PM
outlawjeeper
A 1" body lift with the 2.5 will clear 33's, but if you ran coil spacers with 2.5 lift springs you would be pushing it as far as not making other modifications.
outlawjeeper is offline
post #5 of 35 Old 07-31-2010, 03:06 PM
jenkins_1120
your going to need a 3/4 spacer for the front or you jeep will look slanted. i put one on with the lift when i did it and made it level
jenkins_1120 is offline
post #6 of 35 Old 07-31-2010, 03:45 PM
bmw91
32s would fit perfectly. i got the lift installed about 2 weeks ago and mine sits pretty level even with the 70 extra pounds of winch in the front. if you wanted 33s go with that and a 1 inch body lift or so. you wont have to do any extra mods.
rc even sells a package with the bl. heres the link if you want
1997 - 2006 Jeep TJ Wrangler 2.5" Suspension / 1" Body
bmw91 is offline
post #7 of 35 Old 07-31-2010, 04:10 PM
iceman1947
Dumb question, what is the spacer?
iceman1947 is offline
post #8 of 35 Old 07-31-2010, 04:24 PM Thread Starter
cam36
That package won't work for me I got an 06 6speed, but thanks anyway! Ill just buy it seperately and do you think the 2.5lift with a 1 inch bodylift will rub with 33's if I disco my swaybar?
Spacers are like little hockeypucks that go ontop of your springs for a quick lift, it doesn't involve springs or shocks
cam36 is offline
post #9 of 35 Old 07-31-2010, 04:29 PM
jerseyjeep22
every jeep is different. Dont believe the "you definitly wont need anything besides the lift". I installed the RC 2.5 and guess what? I got vibrations, the solution to which would be a MML. Now is this common? no. Is it possible? yes.
Edit: I ran the 2.5 with 32x11.5 and it was perfect.
jerseyjeep22 is offline
post #10 of 35 Old 07-31-2010, 04:30 PM
vohk
Maybe. A 2.5" lift will give you plenty of up travel with 32s, and adding the 1" BL will do the same for 33s. That being said, you will almost certainly need to lengthen your bumpstops F/R to prevent your tire hitting the fender or shocks fully collapsing before the stops hit the frame. Sway bar hooked up, it won't be a problem for normal driving, but disco'd and off road you definitely want your bumpstops set up right.
Also, as long as you have a <10.5" wide tire (~265mm), you shouldn't rub on the control arms with stock wheel backspacing, or at least not more than a spacer or two on your steering stops will correct.
*edit
vohk is offline
post #11 of 35 Old 07-31-2010, 04:37 PM
TJdualsport
Originally Posted by vohk View Post
Maybe. A 2.5" lift will give you plenty of up travel with 32s, and adding the 1" BL will do the same for 33s. That being said, you will almost certainly need to lengthen your bumpstops F/R to prevent your tire hitting the fender or shocks fully collapsing before the stops hit the frame. [/COLOR].
*edit
it works, but wouldnt say you get plenty of uptravel and since you have to lengthen the bump stops so much it takes away your uptravel even more. make sure they send you the right shocks with the kit for the rear. they have alot of issues getting the right rear shocks with that kit
TJdualsport is offline
post #12 of 35 Old 07-31-2010, 04:38 PM Thread Starter
cam36
Yeah I need to get bumpstops and wheelspacers as well....jeeps are just a hole that you throw your money in haha
cam36 is offline
post #13 of 35 Old 07-31-2010, 07:30 PM
jenkins_1120
why would you need wheel spacers? what kinda backspacing do your wheels have? about the 3/4" spacer everyones jeep is diferent so you might need it or not. my lift i got the 2.5" rc 1" BL, 3/4" fr spacer, currie anti rock, f/r adj track bars. on the rear i have the factory bump stops with the factory sway bar links and i dont have any rubbing issues
post #14 of 35 Old 07-31-2010, 09:33 PM
bmw91
oops. didnt even notice that. i tried haha
bmw91 is offline
post #15 of 35 Old 07-31-2010, 11:05 PM Thread Starter
cam36
I was thiking wheel spacers because you said if my wheel width is <10:5 then I wouldn't need it, if I run 33's then the width would be 12.5 no?
cam36 is offline
rc , rough country , 2.5 , lift , suspension , tj , wrangler
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
Tryin to figure out how I'm running 33's. Lift or body lift question. dm33buckeyes TJ Wrangler Technical Forum 21 08-14-2011 04:06 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 09:11 AM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 08:04 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
