Rattling noise while idling - Page 2 - JeepForum.com
post #16 of 18 Old 03-21-2012, 09:44 PM
Heath
2014 JK Wrangler
A vacuum leak or fad cap not sealing will cause issues as well.
2013 JKU Rubicon
Heath is offline
post #17 of 18 Old 03-21-2012, 10:03 PM
AKGeo
Originally Posted by Jesse2609 View Post
Hi i have a 2005 6 speed manual tj and i bought it used, anyway also when i idle it makes that rattle noise in the transmission, once i put the clutch in it goes away then let out it comes back. I had someone listen to it they said it sounded like the throughout bearing. idk just thought i'd put mine in as well.
Curse of the Jeep manual transmissions and MOPAR fluid. Change your fluid, and I suggest a 3rd party synthetic like AMSOil Synchromesh or Royal Purple Synchromax. Some, but not all, have had success with these as well as Pennzoil synchromesh. I just replaced the fluid in my 5-speed with the Royal Purple and it got rid of the rattle sound and made everything shift much smoother even after it gets hot, whereas before it would stick in gear and shift rough in lower gears.
AKGeo is offline
post #18 of 18 Old 03-21-2012, 10:04 PM
Quantumracer
05 TJL Rubicon w/6 speed manual and 113k on the odometer. I've never heard the trans rattle, but the exhaust brackets have given me fits!!!
Oh, I switched to amsoil a long time ago...that may be the difference. ???
Quantumracer is offline
rattle , noise
99 2.5L rattling noise!!! bpeterson TJ Wrangler Technical Forum 20 11-06-2009 11:44 AM
Noise while idling in Neutral GoneMudding TJ Wrangler Technical Forum 10 08-14-2009 05:43 PM
Rattling noise in steering column. Is worse since lift. Mostly acts up when idling. rem75977 TJ Wrangler Technical Forum 1 04-02-2009 07:58 PM
Transfer Case Noise When Idling. Talos YJ Wrangler Technical Forum 4 07-07-2008 05:53 PM
Rattling noise??? TRF TJ Wrangler Technical Forum 3 02-16-2006 11:10 AM
