Rattling in Neutral - JeepForum.com
post #1 of 11 Old 08-08-2005, 10:29 PM Thread Starter
gnetiv
Rattling in Neutral
Hey guys/gals
I've noticed that when I put my Jeep in neutral and let up the clutch I hear a rattling noise coming from directly under me. Once I engaged the clutch it's gone. Any suggestions on what that may be and how serious of the problem it is.
Thanks in advance
2001 TJ 4.0 Sport
4" Lift; 33" Tires; Borla Cat-Back Exhaust; AtoZ Rockers
White Jeep Club Member #35 Since 8.7.05
/ | [____],
1---L-oOlllllllOo-
()_)()_)----)_)
gnetiv is offline
post #2 of 11 Old 08-08-2005, 10:35 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That is totally normal and not a problem. ALL of our Jeeps make that same noise when in neutral and the clutch is out. It's just the input shaft of the transmission spinning around inside the tranny. We hear such noises in our Jeeps because they're not loaded with soundproofing like cars are.
Gone on vacation until August 25.
Jerry Bransford is online now
post #3 of 11 Old 08-08-2005, 10:37 PM
Flatbroke
yeahn, I took mine to the dealer for the same problem, and they said it was normal.
Yellow 02 Sport
Originally Posted by XRussoX
Haha
I actually look at a Jeepers nuts to see how informed they are. Ditch your nuts man!
Russo
Flatbroke is offline
post #4 of 11 Old 08-08-2005, 10:38 PM Thread Starter
gnetiv
Thanks for the info Jerry..u too flatbroke!!!
I can sleep better now.
2001 TJ 4.0 Sport
/ | [____],
1---L-oOlllllllOo-
()_)()_)----)_)
gnetiv is offline
post #5 of 11 Old 08-08-2005, 10:54 PM
skenzer
skenzer's Avatar
As a buddy of mine once told...."Enjoy that sound..it's the sound of a well built NV3550". Ever since then it's been like music to my ears.
2001 Cherokee Limited
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
Lot's more to do....
skenzer is offline
post #6 of 11 Old 08-09-2005, 07:34 AM
99TJSport
99TJSport's Avatar
I don't have it in front of me now, but there is a TSB issued by Jeep for the NV3550 trannys making rattling noise while in gear, for 00 and 01 I believe.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline
post #7 of 11 Old 08-09-2005, 08:06 AM
paroxysym
2007 WK
that rattle in nuetral with your clutch out is the throw out bearing from what i have been told... normal, havent heard a jeep that doesnt do it.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #8 of 11 Old 08-09-2005, 10:29 AM
99TJSport
99TJSport's Avatar
21-002-01 is the TSB number for gear rattle/noise while in neutral, clutch out. I mis-worded it earlier.
Jeff
post #9 of 11 Old 08-09-2005, 11:25 AM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
Yeah, my '98 does it when shifting, in neutral, and when the rpms drop to less than 1900. Its normal. Haven't seen or heard one that does not do it yet, although it scares the crap out of my passengers I usually get "I'm never riding with you again until you get the transmission fixed." Or "It sounds like your transmission is about to fall out!"
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #10 of 11 Old 08-09-2005, 01:04 PM Thread Starter
gnetiv
PHP Code:
LMAO
I've wanted a Jeep for the longest time and now that I have one...just a bit paranoid Don't want it to break when out on the trails.
Great forum GREAT MEMBERS with GREAT INFO, glad I found it.
Thanks again all.
2001 TJ 4.0 Sport
/ | [____],
1---L-oOlllllllOo-
()_)()_)----)_)
gnetiv is offline
post #11 of 11 Old 08-12-2005, 09:13 PM
CoriolisSTORM
WHAT?!
2010 JK Wrangler
Wait a tick, does anyone know if an AX-5 is supposed to make the sounds like that? I know a NV3550 does, but I've never heard of an AX-5 making it other than mine.....
Rattling sound when in neutral streaker23 TJ Wrangler Technical Forum 10 12-21-2009 01:35 PM
bad vibrations in neutral hoghandler TJ Wrangler Technical Forum 2 06-29-2009 06:24 PM
Anyone have the TSB for rattling in Neutral done on a 2002 sport with NV3550 trans? mjwalfredo TJ Wrangler Technical Forum 11 05-22-2007 09:39 AM
Rattling noise in neutral SmithersGS TJ Wrangler Technical Forum 2 02-06-2005 08:54 AM
Another "rattling in neutral" post swoodnj TJ Wrangler Technical Forum 4 05-31-2004 12:20 PM
