Random Stalling, CEL on Have DTC's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Random Stalling, CEL on Have DTC's
WIN a set of Mammoth Boulder Wheels at ExtremeTerrain.com!Truck & Jeep Fest 2015 - EdmontonFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 01-28-2015, 05:01 PM   #1
Hella
As stated above. Was driving and all of the sudden nothing. Jeep would start to stumble bad and stall. Has happened twice now. Restart it and it would run fine. Specs as follow 04 TJ 4.0 160k New motor at 139k.
Cam Sensor New(when they put the motor in), Crank sensor new, newer coil rail(within a year) cleaned tb.
First time it happened it threw these dtc's. p0340, p0353, p0351, p1391.
Second time now has these dtc's. p0340, p0353, p0352, p0351, p1391.
Also I dont know if it is related but has a rough idle, almost like its chugging and when you raise the rpms a bit its smooth.
just looking for any ideas or areas to check. Thanks!
04 TJ "Leyla" Rubi..
Hella is offline   Reply With Quote Quick reply to this message
