Random shutoff when engine is warm won't start back up - JeepForum.com
post #1 of 4 Old 12-17-2012, 01:38 PM Thread Starter
higgins192
I sent my jeep into the shop to rebuild the front axle. Well 3 weeks later I go to pick it up and I drive it away well a few miles down the road it spiders like its missing and shuts off and it wouldn't crank back over. Well I clean the distributor and that didn't help. So I bought a pick up coil and installed it. It helped but still shut offed and I got a error code P1391 the camshaft sensor seems fine could it be the crankshaft sensor? Please help
higgins192 is offline
post #2 of 4 Old 12-17-2012, 01:59 PM
Jeepsr4me
Yeap thats what it is. Change that.
Jeepsr4me is offline
post #3 of 4 Old 12-17-2012, 03:07 PM
oakmckinley
If you just had it at a shop, check the connection. Maybe they had to remove it and its not connected all the way.
Not sure why they would have to mess with that but who knows.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #4 of 4 Old 01-06-2013, 10:32 AM
daubler1975
2002 XJ Cherokee
check the computer
Had stalling issues, changed cam and crank sensors.....still stalled. Checked the screws around the computer case and saw white corrosion. Took the case out, opened it, and saw that the corrosion had spread into the case and was starting to pop off some tiny circuits from the board. I'm waiting for a new computer to install, but I'm almost 100% sure this was causing the problem.
daubler1975 is offline
engine , missing , p1391 , stalling
