Rancho 2.5" Rock Crawler or Rough Country 4" Long Arm?? - JeepForum.com
post #1 of 2 Old 08-01-2010, 10:15 PM Thread Starter
TombRdr
I'm a newbie who just purchased a 2003 Wrangler Rubicon (Tomb Raider edition #85) with 23k original miles on it and now I'm looking to start playing with it!! My first step is a lift and some tires. I want to run 33X12.5's with a 15X10 wheel (the Tomb Raider has very wide flares and I want to fill them). I have been lurking at this forum and another and have read some good things about the Rancho 2.5" rock crawler lift (with RS9000xl shocks), but I am also interested in the Rough Country 4" long arm lift. This will be a daily driver with only occasional off roading (unless I catch the bug), so street manners are important but at the same time I don't want to be limited to the kiddie trails when I do decide to get a little mud on the tires. My budget for the lift itself is around $1400 so both these kits work, however the Rancho has a $500 rebate that I can use towards other items needed. Any advise or suggestions would be GREATLY appreciated!!
TombRdr is offline
post #2 of 2 Old 08-01-2010, 10:24 PM
jdub36
Well since you are starting with a rubicon axles and gearing should be good to run 33's. You may want to do some more reading on wheel width with 33's. Most are running a 8in wide wheel. As for the lift you might want to look down the road and make sure you don't ever want to run 35's. If you think that may be something you would want to do so you are not limited to certain trails then you might lean towards the long arm. If you think that 33's are as big as you ever want to go then the rancho lift might be your best bet. I am currently running a 4in long arm kit and i love the way it rides.
jw
jdub36 is offline
suspension lift , rancho , rough country
Rancho 3" Rockcrawler + 1" BL or 4" Rough Country Vifilio TJ Wrangler Technical Forum 17 11-13-2010 09:50 AM
Have a rough country 4" lift with da "gangsta lean" jeepguy85 YJ Wrangler Technical Forum 19 05-25-2010 07:11 AM
4" Short Arm... Rock Krawler, Currie, Or Rough Country rastaangel TJ Wrangler Technical Forum 20 10-16-2009 01:10 AM
Installing rear "Warn" rock crawler bumper larry47 JK Wrangler Technical Forum 3 09-11-2009 03:16 PM
Rancho 2.5 rock crawler kit Jakemd98 TJ Wrangler Technical Forum 4 03-29-2006 07:25 AM
