Rampage frameless top help - JeepForum.com
post #1 of 4 Old 05-02-2011, 12:09 PM Thread Starter
Wildcat83
So after running my soft top in safari mode for a few weeks, I recently decided to put the windows back on. I'm having a problem with the rear window/portion of the top. When I install the rear window and tighten the 3 top straps so that the rear window is nice and tight, the window velcro does not meet up with the velcro of the actual top. The actual top velcro is longer, so it seems like the rear window needs to be looser in order to meet up with the velcro, but if I make the window loose it flaps all over. There are 2 strips of velcro at the top of the rear window that meet up with the actual top velcro, and I can't get either of these to meet up; the actual top velcro is too long. I tried tugging on the top to get it to move down more but it doesn't make much of a difference. What am I doing wrong here??
Wildcat83 is offline
post #2 of 4 Old 05-02-2011, 04:07 PM Thread Starter
Wildcat83
bump bump - anyone???
post #3 of 4 Old 05-03-2011, 05:34 AM
scoin
Contact Jake from rampage. I had some problems with my top and he took care of anything. He's on the forum, check out the rampage bowless top thread. http://www.jeepforum.com/forum/f9/ra.../index113.html
scoin is offline
post #4 of 4 Old 05-03-2011, 06:24 AM
Neeco
You may need to loosen the top itself and readjust it so that it sits further towards the rear of the jeep. It wouldn't suprise me that the top has "scooted" towards the motor with the windows out. Take everything loose and see if you can get it to fit better.
"Before he shed any tears for the destruction of civilization and the death of man, he should discover whether civilization was destroyed and whether man was dead" ~ Earth Abides
"When you wake someone up with one hand on their throat and a blade in their mouth they become very compliant." ~ Cause
"You can't get us all"......."That's a fact, but you're first and he's second, do you care what happens after that?" Last stand at Saber River
Neeco is offline
Rampage Frameless soft top Q? Do It xj TJ Wrangler Technical Forum 8 08-15-2011 11:49 AM
Rampage frameless top? highside TJ Wrangler Technical Forum 25 06-15-2011 11:34 PM
Rampage Frameless Softop zu903 TJ Wrangler Technical Forum 10 01-25-2011 11:23 AM
Rampage Frameless top. JC_Sahara Wrangler General Discussion 6 01-25-2011 06:12 AM
Got my rampage frameless top djkbooth TJ Wrangler Technical Forum 4 10-28-2010 08:32 AM
