Ram Air For FREE? - JeepForum.com
post #1 of 9 Old 02-28-2006, 07:17 PM Thread Starter
adp5025
Ram Air For FREE?
Ok guys I was messing around with the stock intake today, checking the filter and such. When looking at the horn of the stock intake, i noticed with enough force you could move the horn to any angle. i pushed it clockwise (from the front view) so it was pointing in the direction of the fan. The engine fan forces the air with a good bit of freash air into the area of the horn.
Also does anyone know if there are negitive affects of doing this, I havent drove with the new direction of the horn but i will be driving 50 miles tommorrow, so i will let you guys know if i see any changes in performace. Most likey it will stay the same Im not sure.
I dont have my cam with me, so i could not take any pictures
Basicly to sum it up just turn the horn of the intake to any angle u want insteed of the 90 deg that it was at. I placed it at 350 deg which points to the engine fan.
1999 Jeep Wrangler Sport 4.0L 5 Speed (Dana 30/186MM Front Axle,3.73 Axle Ratio,Dana M35/194MM Rear Axle)
2004 Jeep Grand Cherokee OVERLAND 4.7H.O. V8
2007 Toyota Tacoma Double Cab 4.0L V6 TRD offroad
Penn State University - Engineering
adp5025 is offline
post #2 of 9 Old 02-28-2006, 07:26 PM
M1Shooter
M1Shooter's Avatar
Why would you want to force hot air into your intake? Any positive effects from forced air will be negated by it's temp.
M1Shooter is offline
post #3 of 9 Old 02-28-2006, 07:30 PM
aussie stu
the cool freah air hitting the radatior isn't so cool or freash when it comes out the other side.
Black 98 TJ / 4.5" Coils / 1" BL + MML / 4.56 / 35's Silverstones MT-117 on 16 X 8's / D44 & ARB Airlocker / D30 & lockright / Rocklights / wind sheild IPF's / Custom WARN rear tyre carrier / extended brake lines / Custom Triangulated 4 link long arm / Front adj. panard (no rear) / rear storage draw system / OBA / AA SYE / Bestop duster, windjammer, bikini combo / Bushwackers flares / UHF / TBS / Wilderness Rack / 3" stainless steel snorkel / T-Max 9000 6HP winch
aussie stu is offline
post #4 of 9 Old 02-28-2006, 07:31 PM Thread Starter
adp5025
Yeah i thought about that just now
Also just thought about another thing, what if i cut a hole directly underneat of the horn (270 deg) and place the horn under the front left wheel well, so it sucks up air from out side the cars engine compartment
adp5025 is offline
post #5 of 9 Old 03-01-2006, 07:24 AM
Jeepin' Rock Cl
Ever see how much mud tires kick up into the fenders? Do you want that in your airbox?
Jeepin' Rock Cl is offline
post #6 of 9 Old 03-01-2006, 08:18 AM
mdot
It's called a "cold air intake". Look for kits online. But the gains are debated and marginal even at best. (On our jeeps that is...other vehicals have other results)
mdot is offline
post #7 of 9 Old 03-01-2006, 08:53 AM
RockRunner85
Or water for that matter if you do any stream crossings.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #8 of 9 Old 03-01-2006, 09:04 AM
Milhouse
From what I understand the reason the horn is faced in that direction is so that the hood helps protect it from getting water/mud into the air box. By moving/drilling the hold you run the risk of sucking up water into the engine and creating a whole bunch of problems...
Milhouse is offline
post #9 of 9 Old 03-01-2006, 09:14 AM
Muddeprived
Muddeprived's Avatar
You will gain very little with the ram-air effect. I have a custom 3" snorkel that pops out of the hood and i run a 90 degree pvc that faces forward on the highway. I cannot notice any difference in power, high or low rpms. My buddy's yj has a custom 3" snorkel just like the arb and has the same 90 degree pvc angle on top, facing forward. He too didn't notice any gains. We both have the 4 cyl.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
so i got a free DS for my SYE jeepsteads TJ Wrangler Technical Forum 3 03-11-2008 07:29 PM
Free 8.8!! dand3053 YJ Wrangler Technical Forum 16 03-09-2008 11:33 AM
Free Membership Give-a-way is now up to SEVEN free memberships Richmond88yj YJ Wrangler Technical Forum 21 01-13-2008 08:42 PM
Free-bee 350 Wood Butcher YJ Wrangler Technical Forum 2 09-07-2004 07:50 PM
My Free 3M Mod u4ea TJ Wrangler Technical Forum 21 08-22-2003 06:01 AM
